It is currently Sat Nov 23, 2024 10:46 pm
 Post subject: RSC FORTH v1.7
PostPosted: Sat Jul 28, 2018 12:07 pm
I found this a while ago. It's an archive of source files for a Rockwell Forth chip that some may we familiar with. I will add other documentation as well here.
Cheers!
Andy
RSC_Forth_V1.7.zip [563.74 KiB]
Downloaded 322 times
 Post subject: Re: RSC FORTH v1.7
PostPosted: Sat Jul 28, 2018 12:09 pm
Here is the RSC Forth User Manual.
RSC-FORTH_User's_Manual.pdf [1.97 MiB]
Downloaded 378 times
PostPosted: Sat Jul 28, 2018 12:19 pm
Here are some informational pdfs.
Cheers!
rockwell_r65frx_r65fkx_rsc_forth_roms.pdf [542.8 KiB]
Downloaded 312 times
R65FRxFKx Datasheet.pdf [442.59 KiB]
Downloaded 305 times
R65F11_R65F12_Datasheet.pdf [1.08 MiB]
Downloaded 300 times
PostPosted: Mon Jul 30, 2018 12:08 am
Interesting to see the source code preserved. Rockwell went on to add extra hardware to their 6502 cores to support forth directly. This consisted of a 16-bit register called I, and 10 new instructions to support a direct threaded interpreter. It would be interesting to see the source code of the newer forth interpreter that took advantage of these instructions, although I'd think that the implementation would be quite simple as most of it is implemented in the new instructions. Pretty much all of the Rockwell and Conexant modems used these updates 6502 cores.
PostPosted: Mon Jul 30, 2018 2:36 am
Thank you for uploading that, Andy. The Forth tutorial is very well written.
PostPosted: Fri Aug 03, 2018 8:59 pm
Welcome, Mike.
I've found that whoever wrote Rockwell's documentation did an exceptional job IMO.
PostPosted: Tue Aug 07, 2018 1:04 pm
To extend this thread a bit, the Rockwell R65C19 device incorporated several complex peripherals onto the chip, support threaded code, and support for digital signal processing. BigEd has a short review of the instruction set here.
Michael A.
PostPosted: Fri Feb 17, 2023 5:13 am
Wow! Thanks so much everyone!
