It is currently Sat Nov 23, 2024 10:53 pm
PostPosted: Sun Jan 23, 2022 7:43 am
includes the making of the 6502 silicon
https://www.youtube.com/watch?v=WBqGyf8eQVk
posted Jan 22, 2022
In the description:
    Using machine learning on some scenes (see pinned comment & description) we've digitally remastered the only known, low-quality footage of the Commodore 64 & 6502 factory production to better show how the world's bestselling computer was made!
    You may have seen the original very low quality German VHS factory tour of MOS and Commodore that's been around for years (https://youtu.be/xu8Fi0tC9IA). Sadly a higher quality version never showed up. I've been wanting to do this for a while but the technology only recently got to an acceptable level. It's far from perfect, and the machine learning sharpening can look a little odd occasionally, but I hope you agree that it's better and more palatable than the original, all just in time for the C64's 40th anniversary. I plan future versions as the tech improves. Here's how I made this one:
    AUDIO: I created a file of the German captions and translated it to English then re-synced that to the footage, and reworded it where needed. I also added back in all the sound effects from a foley library because the original German audio was muted.
    VIDEO: I used Topaz Labs machine learning video enhancer (https://www.topazlabs.com/video-enhan...) to create 5 versions of the footage. Some levels of restoration can make the people look cartoony, so by using different levels, I was able to cut each shot to its most natural look and ensure I felt it really was an improvement over the original. Occasionally I use the original shot with only upscaling to 4K. Some shots actually use different levels on different parts of the same frame using masks, so you might see sharp C64 motherboards, but the worker's more natural less reworked face above them, all in one image.
    There are qutie extreme flashing colours in the original. I placed a duplicate of each shot above the original, made it 50% transparent, and offset it by 1 frame. This reduces the flashing producing a more uniform effect. Sadly some flashing remains, but removing this further would have led to ghosting of movement.
    I then trimmed the flickering edges of the image off and extended it to near widescreen using a blurred enlarged version to fill the sides.
    I also cut out about 7 minutes of unnecessary stock footage, corporate marketing, & overly long shots to again make things more watchable.
    Aside from that there was colour balancing, brightening, and sharpening where possible. Enhance!
    THUMBNAIL: This too is a remastered black and white low-res shot, with faces enhanced using Remini, colourized, and some other little tricks to bring it more to life!
    0:00 Intro & context
    3:39 How silicon is made
    4:51 Circuit blueprints
    8:26 Circuit production
    11:49 Chip testing & cutting
    13:34 Finishing the chip
    15:28 C64 PCB assembly
    17:17 C64 assembly & testing
    20:49 Packaging & finish
PostPosted: Sun Jan 23, 2022 5:10 pm
The narrator's voice is so soothing ... I can't place the accent, but it's very nice and not at all distracting. He needs to market voice-overs for darn near everything and earn a fortune.
PostPosted: Sun Jan 23, 2022 5:12 pm
Since you say that, it comes to mind it might be the one who tells about all the C64 stuff with his dog by his side.
PostPosted: Sun Jan 23, 2022 5:25 pm
Yep, I just checked, and it's UK-born Christian Simpson, aka Perifractic. He had a bit part in The Phantom Menace.
https://www.perifractic.com/
