It is currently Sun Nov 24, 2024 1:18 am
PostPosted: Fri Aug 16, 2013 9:47 pm
I'm sorry, but I have been searching Google and Bing for a while now and I cant find one. To clear anything up I will explain what I am looking for. I need a chart that show stuff like
$FFD2 --> Output Char
I want to have a chart of all the KERNAL ROM functions and there corresponding memory location
JMP $FFD2
PostPosted: Fri Aug 16, 2013 10:00 pm
The answer is in my post at viewtopic.php?f=2&t=2605&p=27409#p27409 . The book gives all the entry points.
PostPosted: Sat Aug 17, 2013 12:28 am
Try this. The top entry did it for me.
http://lmgtfy.com/?q=commodore+64+kernal+entry+points
No disrespect, but I cannot imagine what you were googling for. Commodore 64 is one of the most documented computers. The phrase 'ROM codes' is not meaningful; you want to look for kernal documentation, entry points, list of routines, etc.
PostPosted: Sat Aug 17, 2013 8:00 am
Even this worked:
https://www.google.co.uk/search?q=FFD2+ ... utput+Char
which is directly from James' post... It is curious that James was unable to find what he wanted. Here's a possibility: in the old days you put into a search query some words or phrases which are likely to be in the document you seek and unlikely to be in any other document. These days it's also possible to type in a natural language query, such as "what are the commodore rom codes", at which point you are trusting to some sophisticated heuristics which are still in infancy.
James: perhaps you've never used a command line? Unix and Linux have "grep" and DOS (Windows) has "find", in both cases you say what text you are looking for and the command can return the names of files which contain the text. That's the way we always used to use search engines, and it still works well.
PostPosted: Sat Aug 17, 2013 1:38 pm
http://lmgtfy.com/?q=Commodore+64+Kernal+rom+map
This is what I searched for on Bing and Google
I came to this http://sta.c64.org/cbm64mem.html , but when I found the Kernal ROM memory this is what it said
KERNAL ROM or RAM area (8192 bytes); depends on the value of bits #0-#2 of the processor port at memory address $0001:
%x0x: RAM area.
%x1x: KERNAL ROM
not very helpful, however I found a GEOS memory map
JMP $FFD2
PostPosted: Sun Aug 18, 2013 6:53 am
%x0x: RAM area.
%x1x: KERNAL ROM
Recommendation: avoid Google and Bing, especially the latter. What you see isn't necessarily what you should get. Both Garth and I strongly suggest the use of Ixquick for web searches.
That said, here's something for you from my development library:
;STANDARD KERNEL ROM JUMP TABLE
acptr    =$ffa5                ;input byte from serial bus
basin    =$ffcf                ;input a byte, also chrin
bsout    =$ffd2                ;output a byte, aka chrout
chkin    =$ffc6                ;define an input channel
chkout   =$ffc9                ;define an output channel
chrin    =basin                ;input a byte
chrout   =bsout                ;output a byte
cint     =$ff81                ;initialize screen editor & VIC
ciout    =$ffa8                ;output byte to serial bus
clall    =$ffe7                ;close all files
close    =$ffc3                ;close a logical file
clrchn   =$ffcc                ;restore default devices
getin    =$ffe4                ;get a byte
iobase   =$fff3                ;get I/O block base address
ioinit   =$ff84                ;initialize I/O devices
listen   =$ffb1                ;command serial bus device to LISTEN
load     =$ffd5                ;load from device
membot   =$ff9c                ;read/set bottom of memory pointer
memtop   =$ff99                ;read/set top of memory pointer
open     =$ffc0                ;open a logical file
plot     =$fff0                ;read/set position of cursor on screen
ramtas   =$ff87                ;initialize RAM, tape buffer, screen
rdtim    =$ffde                ;read the software clock
readst   =$ffb7                ;read I/O status word
restor   =$ff8a                ;restore default I/O vectors
save     =$ffd8                ;save to a device
scnkey   =$ff9f                ;scan the keyboard
screen   =$ffed                ;read number of screen rows & columns
second   =$ff93                ;send SA after LISTEN
setlfs   =$ffba                ;set logical file parameters
setmsg   =$ff90                ;set kernel message control flag
setnam   =$ffbd                ;set filename parameters
settim   =$ffdb                ;set the software clock
settmo   =$ffa2                ;set IEEE time-out flag
stop     =$ffe1                ;check the STOP key
talk     =$ffb4                ;command serial bus device to TALK
tksa     =$ff96                ;send SA after TALK
udtim    =$ffea                ;update the software clock
unlsn    =$ffae                ;command serial bus device to UNLISTEN
untlk    =$ffab                ;command serial bus device to UNTALK
vector   =$ff8d                ;read/set I/O vector table
;C-128 EXTENDED KERNEL JUMP TABLE
bootdsk  =$ff53                ;attempt boot from disk device 8
closall  =$ff4a                ;close all files on device in .A
crti     =$ff33                ;common interrupt return
dlchr    =$ff62                ;initialize VDC char RAM
dmacall  =$ff50                ;drive DMA controller
pfkey    =$ff65                ;assign string to F-key
getcfg   =$ff6b                ;translate bank to MMU pattern
go64     =$ff4d                ;switch to C-64 mode
indcmp   =$ff7a                ;compare .A to byte in remote bank
indfet   =$ff74                ;get byte from remote bank
indsta   =$ff77                ;put byte to remote bank
jmpfar   =$ff71                ;jump to routine in remote bank
jsrfar   =$ff6e                ;call subroutine in remote bank
lkupla   =$ff59                ;look up LA
lkupsa   =$ff5c                ;look up SA
phoenix  =$ff56                ;initialize option ROMs & boot from disk
primm    =$ff7d                ;print following string
setbnk   =$ff68                ;set bank for load/save
spinout  =$ff47                ;set up fast serial bus
swapper  =$ff5f                ;swap active display
   .end
PostPosted: Sun Aug 18, 2013 3:34 pm
I never owned a Commodore machine, I was an in the Atari camp.
But we had books such as "Mapping the Atari" which basically tried to document most every memory location and ROM call within the computer. It was always good reading.
Searching for a similar thing for the C64 revealed this: http://unusedino.de/ec64/technical/proj ... g_c64.html
It's long, I didn't do an exhaustive scan, but it seems comprehensive. I'm sure more exploration of "mapping c64" in a search engine should bring up other interesting documents.
PostPosted: Mon Aug 19, 2013 8:46 pm
I did an exhaustive scan.... when I typed that in years ago. ;)
It's an excellent low-level reference, but for starting to learn the kernal routines, I'd recommend the official C64 Programmer's Reference Manual instead. (PDFs, Text) Starting off with the Mapping book kind of obfuscates the main API in all the details.
PostPosted: Tue Aug 20, 2013 6:11 am
I saw that impressive labor of love. Did that experience bring your WPM up, from hours of practice, or down, from repetitive motion injury?
Mike
PostPosted: Wed Aug 21, 2013 2:44 am
I've never had RSI. I'm not sure if that's from starting to type at a very young age and thus adapted to it, or concentrating on good typing posture as I got older.
But yeah, I typed in a few books for the masochistic interests of typing speed practice & thorough content exposure, and because at that time scans were unwieldy (phone modems were still the norm) and not OCR'd.
Users browsing this forum: No registered users and 35 guests
