It is currently Sun Sep 22, 2024 4:37 am
 Post subject: CVBasic compiler v0.6.0
PostPosted: Wed Aug 07, 2024 11:33 pm
Hi all.
I created this BASIC compiler originally for Z80 machines, however, I was intrigued by the fact that there are consoles with TMS9918 video processors, but 6502 processor!
In this case I decided to target the Vtech Creativision (also known as Dick Smith's Wizzard).
Of course, re-coding a whole Z80 compiler to support 6502 was pretty an achievement! Also rewriting the whole library. :D
CVBasic v0.6.0 is pretty complete, and all the example programs should compile just fine for Creativision. (just use the --creativision switch)
There are several examples and minigames included.
The Creativision Emulator is available from https://sourceforge.net/projects/creativisionemulator/
I've enlisted the help of some people to test in real hardware, but in the meanwhile, enjoy it! 8)
P.S: The full manual for the compiler is included, there is also my book Programming Games for Colecovision that fully applies to the Creativision port.
P.S.2: The source code for the compiler is available at https://github.com/nanochess/cvbasic
File comment: Camelot Knights game (use camelot2.bas)
camelot_knights_cvbasic.zip [65.9 KiB]
Downloaded 8 times
File comment: CVBasic v0.6.0 compiler
cvbasic_v0.6.0.zip [494.56 KiB]
Downloaded 16 times
Author, IOCCC+JS1K winner, Princess Quest in Evercade Intellivision, MSX/Atari/CV/Intellivision/SMS game dev, Knight of boot sector games, IntyBASIC/CVBasic creator.
PostPosted: Thu Aug 08, 2024 6:33 am
Looks interesting! (I experienced mild disorientation that gasm80 now also supports 6502 but that's fine!)
PostPosted: Mon Aug 12, 2024 4:51 pm
I'm glad you like it.
I needed a certain set of assembler features to support CVBasic, so it was easier to make gasm80 to support 6502. An option could be making gasm02 :D but the 6502 instruction set is pretty small so it fits perfectly in gasm80.
I see there are several homebrew computers based on 6502 and using TMS9918, it shouldn't be too difficult for users to make adaptations in the source code of CVBasic.
cron
