JohanFr wrote:
However, the documention for writing to T1L ($06) worries me:
Is it WDC documentation you're using? Not a great choice, IMO... for 65C22, 65C02 and others I much prefer the doc from Rockwell... but even their 65C22 doc is occasionally hard to understand. That's because the chip itself has some subtle (but useful) nuances.
"8 bits loaded into T1 low order latches. This operation is no different than a write into the T1 Low Order Register"
T1 Low Order Register? So, we're drawing a contrast between Reg $06 and Reg $04, is that right?
According to my notes (based on Rockwell), Register $04 and Register $06 behave almost identically... and the exception pertains to reads (not writes). A read of Reg 6 won't clear the T1 flag in the IFR, whereas a read of Reg 4
will clear the flag. (Both return the same data. But the designers apparently anticipated a need to be able to peek at the timer without scuttling a nascent interrupt.)
I suspect that the snippet you quoted is some author's garbled re-interpretation of the behavior documented by Rockwell.
Edit: oops, that's probably too harsh. The snippet isn't incorrect. But it's entirely unhelpful unless there's an accompanying snippet that pertains to reads, whose behavior
does differ between Reg 4 and 6.
Edit: On a broader scale (ie, 65C22 aside), when one finds doc confusing, it can often be helpful to find an alternative version of said doc.
