It is currently Sun Nov 24, 2024 10:43 pm
PostPosted: Tue Nov 07, 2023 9:19 pm
I was porting sweet16 to a 6502 IDE that I am developing and I noticed some things that are wrong.
I took the code from here
http://www.6502.org/source/interpreters/sweet16.htm
The original article is here
https://archive.org/details/byte-magazine-1977-11-rescan/page/n152/mode/1up?view=theater
code from this site
SW16D   LDA  >SET           ;COMMON HIGH BYTE FOR ALL ROUTINES
        PHA                 ;PUSH ON STACK FOR RTS
        LDY  $0
        LDA  (R15L),Y       ;FETCH INSTR
        AND  $F             ;MASK REG SPECIFICATION
code from the article
        LDY  #$0
        AND  #$F            ;MASK REG SPECIFICATION
in any case here is my port that should work with almost any Assembler
I would change change the .ORG and zero page usage
;*   APPLE-II  PSEUDO MACHINE   *
;*         INTERPRETER          *
;*      COPYRIGHT (C) 1977      *
;*     APPLE COMPUTER,  INC     *
;*     ALL  RIGHTS RESERVED     *
;*         S. WOZNIAK           *
;* TITLE:  SWEET 16 INTERPRETER *
R0L     .EQU  $0
R0H     .EQU  $1
R14H    .EQU  $1D
R15L    .EQU  $1E
R15H    .EQU  $1F
        .ORG  $F689
        ;AST  32
        JSR  SAVE           ;PRESERVE 6502 REG CONTENTS
        PLA
        STA  R15L           ;INIT SWEET16 PC
        PLA                 ;FROM RETURN
        STA  R15H           ;ADDRESS
SW16B   JSR  SW16C          ;INTERPRET AND EXECUTE
        JMP  SW16B          ;ONE SWEET16 INSTR.
SW16C   INC  R15L
        BNE  SW16D          ;INCR SWEET16 PC FOR FETCH
        INC  R15H
        LDY  #$0
        ASL                 ;DOUBLE FOR TWO BYTE REGISTERS
        TAX                 ;TO X REG FOR INDEXING
        LSR
        EOR  (R15L),Y       ;NOW HAVE OPCODE
        BEQ  TOBR           ;IF ZERO THEN NON-REG OP
        STX  R14H           ;INDICATE "PRIOR RESULT REG"
        LSR
        LSR                 ;OPCODE*2 TO LSB'S
        LSR
        TAY                 ;TO Y REG FOR INDEXING
        LDA  OPTBL-2,Y      ;LOW ORDER ADR BYTE
        PHA                 ;ONTO STACK
        RTS                 ;GOTO REG-OP ROUTINE
TOBR    INC  R15L
        BNE  TOBR2          ;INCR PC
        INC  R15H
TOBR2   LDA  BRTBL,X        ;LOW ORDER ADR BYTE
        PHA                 ;ONTO STACK FOR NON-REG OP
        LDA  R14H           ;"PRIOR RESULT REG" INDEX
        LSR                 ;PREPARE CARRY FOR BC, BNC.
        RTS                 ;GOTO NON-REG OP ROUTINE
RTNZ    PLA                 ;POP RETURN ADDRESS
        PLA
        JSR  RESTORE        ;RESTORE 6502 REG CONTENTS
        JMP  (R15L)         ;RETURN TO 6502 CODE VIA PC
SETZ    LDA  (R15L),Y       ;HIGH ORDER BYTE OF CONSTANT
        STA  R0H,X
        DEY
        LDA  (R15L),Y       ;LOW ORDER BYTE OF CONSTANT
        STA  R0L,X
        TYA                 ;Y REG CONTAINS 1
        SEC
        ADC  R15L           ;ADD 2 TO PC
        STA  R15L
        BCC  SET2
        INC  R15H
SET2    RTS
OPTBL   .BYTE  SET-1        ;1X
BRTBL   .BYTE  RTN-1        ;0
        .BYTE  LD-1         ;2X
        .BYTE  BR-1         ;1
        .BYTE  ST-1         ;3X
        .BYTE  BNC-1        ;2
        .BYTE  LDAT-1       ;4X
        .BYTE  BC-1         ;3
        .BYTE  STAT-1       ;5X
        .BYTE  BP-1         ;4
        .BYTE  LDDAT-1      ;6X
        .BYTE  BM-1         ;5
        .BYTE  STDAT-1      ;7X
        .BYTE  BZ-1         ;6
        .BYTE  POP-1        ;8X
        .BYTE  BNZ-1        ;7
        .BYTE  STPAT-1      ;9X
        .BYTE  BM1-1        ;8
        .BYTE  ADD-1        ;AX
        .BYTE  BNM1-1       ;9
        .BYTE  SUB-1        ;BX
        .BYTE  BK-1         ;A
        .BYTE  POPD-1       ;CX
        .BYTE  RS-1         ;B
        .BYTE  CPR-1        ;DX
        .BYTE  BS-1         ;C
        .BYTE  INR-1        ;EX
        .BYTE  NUL-1        ;D
        .BYTE  DCR-1        ;FX
        .BYTE  NUL-1        ;E
        .BYTE  NUL-1        ;UNUSED
        .BYTE  NUL-1        ;F
;* FOLLOWING CODE MUST BE
;* CONTAINED ON A SINGLE PAGE!
SET     BPL  SETZ           ;ALWAYS TAKEN
LD      LDA  R0L,X
BK      .EQU  *-1
        STA  R0L
        LDA  R0H,X          ;MOVE RX TO R0
        STA  R0H
        RTS
ST      LDA  R0L
        STA  R0L,X          ;MOVE R0 TO RX
        LDA  R0H
        STA  R0H,X
        RTS
STAT    LDA  R0L
STAT2   STA  (R0L,X)        ;STORE BYTE INDIRECT
        LDY  $0
STAT3   STY  R14H           ;INDICATE R0 IS RESULT NEG
INR     INC  R0L,X
        BNE  INR2           ;INCR RX
        INC  R0H,X
INR2    RTS
LDAT    LDA  (R0L,X)        ;LOAD INDIRECT (RX)
        STA  R0L            ;TO R0
        LDY  $0
        STY  R0H            ;ZERO HIGH ORDER R0 BYTE
        BEQ  STAT3          ;ALWAYS TAKEN
POP     LDY  $0             ;HIGH ORDER BYTE = 0
        BEQ  POP2           ;ALWAYS TAKEN
POPD    JSR  DCR            ;DECR RX
        LDA  (R0L,X)        ;POP HIGH ORDER BYTE @RX
        TAY                 ;SAVE IN Y REG
POP2    JSR  DCR            ;DECR RX
        LDA  (R0L,X)        ;LOW ORDER BYTE
        STA  R0L            ;TO R0
        STY  R0H
POP3    LDY  $0             ;INDICATE R0 AS LAST RESULT REG
        STY  R14H
        RTS
LDDAT   JSR  LDAT           ;LOW ORDER BYTE TO R0, INCR RX
        LDA  (R0L,X)        ;HIGH ORDER BYTE TO R0
        STA  R0H
        JMP  INR            ;INCR RX
STDAT   JSR  STAT           ;STORE INDIRECT LOW ORDER
        LDA  R0H            ;BYTE AND INCR RX. THEN
        STA  (R0L,X)        ;STORE HIGH ORDER BYTE.
        JMP  INR            ;INCR RX AND RETURN
STPAT   JSR  DCR            ;DECR RX
        LDA  R0L
        STA  (R0L,X)        ;STORE R0 LOW BYTE @RX
        JMP  POP3           ;INDICATE R0 AS LAST RESULT REG
DCR     LDA  R0L,X
        BNE  DCR2           ;DECR RX
        DEC  R0H,X
DCR2    DEC  R0L,X
        RTS
SUB     LDY  $0             ;RESULT TO R0
CPR     SEC                 ;NOTE Y REG = 13*2 FOR CPR
        LDA  R0L
        SBC  R0L,X
        STA  R0L,Y          ;R0-RX TO RY
        LDA  R0H
        SBC  R0H,X
SUB2    STA  R0H,Y
        TYA                 ;LAST RESULT REG*2
        ADC  $0             ;CARRY TO LSB
        STA  R14H
        RTS
ADD     LDA  R0L
        ADC  R0L,X
        STA  R0L            ;R0+RX TO R0
        LDA  R0H
        ADC  R0H,X
        LDY  $0             ;R0 FOR RESULT
        BEQ  SUB2           ;FINISH ADD
BS      LDA  R15L           ;NOTE X REG IS 12*2!
        JSR  STAT2          ;PUSH LOW PC BYTE VIA R12
        LDA  R15H
        JSR  STAT2          ;PUSH HIGH ORDER PC BYTE
BR      CLC
BNC     BCS  BNC2           ;NO CARRY TEST
BR1     LDA  (R15L),Y       ;DISPLACEMENT BYTE
        BPL  BR2
        DEY
BR2     ADC  R15L           ;ADD TO PC
        STA  R15L
        TYA
        ADC  R15H
        STA  R15H
BNC2    RTS
BC      BCS  BR
        RTS
BP      ASL                 ;DOUBLE RESULT-REG INDEX
        LDA  R0H,X          ;TEST FOR PLUS
        BPL  BR1            ;BRANCH IF SO
        RTS
BM      ASL                 ;DOUBLE RESULT-REG INDEX
        TAX
        LDA  R0H,X          ;TEST FOR MINUS
        BMI  BR1
        RTS
BZ      ASL                 ;DOUBLE RESULT-REG INDEX
        TAX
        LDA  R0L,X          ;TEST FOR ZERO
        ORA  R0H,X          ;(BOTH BYTES)
        BEQ  BR1            ;BRANCH IF SO
        RTS
BNZ     ASL                 ;DOUBLE RESULT-REG INDEX
        TAX
        LDA  R0L,X          ;TEST FOR NON-ZERO
        BNE  BR1            ;BRANCH IF SO
        RTS
BM1     ASL                 ;DOUBLE RESULT-REG INDEX
        TAX
        LDA  R0L,X          ;CHECK BOTH BYTES
        AND  R0H,X          ;FOR $FF (MINUS 1)
        EOR  $FF
        RTS
BNM1    ASL                 ;DOUBLE RESULT-REG INDEX
        TAX
        LDA  R0L,X
        AND  R0H,X          ;CHECK BOTH BYTES FOR NO $FF
        EOR  $FF
        BNE  BR1            ;BRANCH IF NOT MINUS 1
NUL     RTS
RS      LDX  $18            ;12*2 FOR R12 AS STACK POINTER
        JSR  DCR            ;DECR STACK POINTER
        LDA  (R0L,X)        ;POP HIGH RETURN ADDRESS TO PC
        STA  R15H
        JSR  DCR            ;SAME FOR LOW ORDER BYTE
        LDA  (R0L,X)
        STA  R15L
        RTS
RTN     JMP  RTNZ
;* SAVE/RESTORE ROUTINES
;* FOR NON APPLE-II SYSTEMS
ASAVE   .EQU $45
XSAVE   .EQU $46
YSAVE   .EQU $47
PSAVE   .EQU $48
SAVE
        STA ASAVE
        STX XSAVE           ;SAVE 6502 CONTENTS *
        STY YSAVE
        PHP
        PLA
        STA PSAVE
        RTS
RESETORE
        LDA PSAVE
        PHA
        LDA ASAVE
        LDX XSAVE          ; RESTORE 6502 REG CONTENTS
        LDY YSAVE
        PLP
        RTS
PostPosted: Tue Nov 07, 2023 9:41 pm
Please refer to http://www.easy68k.com/paulrsm/6502/SW16RB.TXT for a solid looking reference. All seven of the LDY $0 instructions need to be LDY #$0, and the EOR $FF needs to be EOR #$FF ... it's possible (likely) that there are other similar operand errors in the above mentioned sources.
Relocating the Sweet16 registers and the interpreter itself are possible, but rather tricky, and should not be attempted by a casual novice.
PostPosted: Tue Nov 07, 2023 10:07 pm
It's worth looking at this previous thread from 2021
viewtopic.php?f=1&t=6745
PostPosted: Tue Nov 07, 2023 10:58 pm
PostPosted: Wed Nov 08, 2023 2:06 am
I now have it assembled and running with my assembler Pasm
https://github.com/pebmeister/Pasm
Processing sweet16.asm
                                          ;*   APPLE-II PSEUDO   *
                                          ;* MACHINE INTERPRETER *
                                          ;*   COPYRIGHT 1977    *
                                          ;* APPLE COMPUTER INC  *
                                          ;*     S. WOZNIAK      *
        ; TITLE "SWEET16 INTERPRETER"
                                          R0L      .EQU   $0
                                          R0H      .EQU   $1
                                          R14H     .EQU   $1D
                                          R15L     .EQU   $1E
                                          R15H     .EQU   $1F
                                          SW16PAG  .EQU   >SET      ; $F7
                                                   .ORG   $F689
$F689: $20 $FD $F7    jsr $F7FD           SW16     JSR   SAVE       ;PRESERVE 6502 REG CONTENTS
$F68C: $68            pla                          PLA
$F68D: $85 $1E        sta $1E                      STA   R15L       ;INIT SWEET16 PC
$F68F: $68            pla                          PLA              ;FROM RETURN
$F690: $85 $1F        sta $1F                      STA   R15H       ;  ADDRESS
$F692: $20 $98 $F6    jsr $F698           SW16B    JSR   SW16C      ;INTERPRET AND EXECUTE
$F695: $4C $92 $F6    jmp $F692                    JMP   SW16B      ;ONE SWEET16 INSTR.
$F698: $E6 $1E        inc $1E             SW16C    INC   R15L
$F69A: $D0 $02        bne $F69E                    BNE   SW16D      ;INCR SWEET16 PC FOR FETCH
$F69C: $E6 $1F        inc $1F                      INC   R15H
$F69E: $A9 $F7        lda #$F7            SW16D    LDA   #SW16PAG
$F6A0: $48            pha                          PHA              ;PUSH ON STACK FOR RTS
$F6A1: $A0 $00        ldy #$00                     LDY   #$0
$F6A3: $B1 $1E        lda ($1E),y                  LDA   (R15L),Y   ;FETCH INSTR
$F6A5: $29 $0F        and #$0F                     AND   #$F        ;MASK REG SPECIFICATION
$F6A7: $0A            asl                          ASL              ;DOUBLE FOR TWO BYTE REGISTERS
$F6A8: $AA            tax                          TAX              ;TO X REG FOR INDEXING
$F6A9: $4A            lsr                          LSR
$F6AA: $51 $1E        eor ($1E),y                  EOR   (R15L),Y   ;NOW HAVE OPCODE
$F6AC: $F0 $0B        beq $F6B9                    BEQ   TOBR       ;IF ZERO THEN NON-REG OP
$F6AE: $86 $1D        stx $1D                      STX   R14H       ;INDICATE'PRIOR RESULT REG'
$F6B0: $4A            lsr                          LSR
$F6B1: $4A            lsr                          LSR              ;OPCODE*2 TO LSB'S
$F6B2: $4A            lsr                          LSR
$F6B3: $A8            tay                          TAY              ;TO Y REG FOR INDEXING
$F6B4: $B9 $E1 $F6    lda $F6E1,y                  LDA   OPTBL-2,Y  ;LOW ORDER ADR BYTE
$F6B7: $48            pha                          PHA              ;ONTO STACK
$F6B8: $60            rts                          RTS              ;GOTO REG-OP ROUTINE
$F6B9: $E6 $1E        inc $1E             TOBR     INC   R15L
$F6BB: $D0 $02        bne $F6BF                    BNE   TOBR2      ;INCR PC
$F6BD: $E6 $1F        inc $1F                      INC   R15H
$F6BF: $BD $E4 $F6    lda $F6E4,x         TOBR2    LDA   BRTBL,X    ;LOW ORDER ADR BYTE
$F6C2: $48            pha                          PHA              ;ONTO STACK FOR NON-REG OP
$F6C3: $A5 $1D        lda $1D                      LDA   R14H       ;'PRIOR RESULT REG' INDEX
$F6C5: $4A            lsr                          LSR              ;PREPARE CARRY FOR BC, BNC.
$F6C6: $60            rts                          RTS              ;GOTO NON-REG OP ROUTINE
$F6C7: $68            pla                 RTNZ     PLA              ;POP RETURN ADDRESS
$F6C8: $68            pla                          PLA
$F6C9: $20 $08 $F8    jsr $F808                    JSR   RESTORE    ;RESTORE 6502 REG CONTENTS
$F6CC: $6C $1E $00    jmp ($001E)                  JMP   (R15L)     ;RETURN TO 6502 CODE VIA PC
$F6CF: $B1 $1E        lda ($1E),y         SETZ     LDA   (R15L),Y   ;HIGH-ORDER BYTE OF CONSTANT
$F6D1: $95 $01        sta $01,x                    STA   R0H,X
$F6D3: $88            dey                          DEY
$F6D4: $B1 $1E        lda ($1E),y                  LDA   (R15L),Y   ;LOW-ORDER BYTE OF CONSTANT
$F6D6: $95 $00        sta $00,x                    STA   R0L,X
$F6D8: $98            tya                          TYA              ;Y-REG CONTAINS 1
$F6D9: $38            sec                          SEC
$F6DA: $65 $1E        adc $1E                      ADC   R15L       ;ADD 2 TO PC
$F6DC: $85 $1E        sta $1E                      STA   R15L
$F6DE: $90 $02        bcc $F6E2                    BCC   SET2
$F6E0: $E6 $1F        inc $1F                      INC   R15H
$F6E2: $60            rts                 SET2     RTS
                                                   .BYTE   LD-1       ;2X
                                                   .BYTE   BR-1       ;1
                                                   .BYTE   ST-1       ;3X
                                                   .BYTE   BNC-1      ;2
                                                   .BYTE   LDAT-1     ;4X
                                                   .BYTE   BC-1       ;3
                                                   .BYTE   STAT-1     ;5X
                                                   .BYTE   BP-1       ;4
                                                   .BYTE   LDDAT-1    ;6X
                                                   .BYTE   BM-1       ;5
                                                   .BYTE   STDAT-1    ;7X
                                                   .BYTE   BZ-1       ;6
                                                   .BYTE   POP-1      ;8X
                                                   .BYTE   BNZ-1      ;7
                                                   .BYTE   STPAT-1    ;9X
                                                   .BYTE   BM1-1      ;8
                                                   .BYTE   ADD-1      ;AX
                                                   .BYTE   BNM1-1     ;9
                                                   .BYTE   SUB-1      ;BX
                                                   .BYTE   BK-1       ;A
                                                   .BYTE   POPD-1     ;CX
                                                   .BYTE   RS-1       ;B
                                                   .BYTE   CPR-1      ;DX
                                                   .BYTE   BS-1       ;C
                                                   .BYTE   INR-1      ;EX
                                                   .BYTE   NUL-1      ;D
                                                   .BYTE   DCR-1      ;FX
                                                   .BYTE   NUL-1      ;E
                                                   .BYTE   NUL-1      ;UNUSED
                                                   .BYTE   NUL-1      ;F
$F703: $10 $CA        bpl $F6CF           SET      BPL   SETZ       ;ALWAYS TAKEN
$F705: $B5 $00        lda $00,x           LD       LDA   R0L,X
                                          BK       .EQU   *-1
$F707: $85 $00        sta $00                      STA   R0L
$F709: $B5 $01        lda $01,x                    LDA   R0H,X      ;MOVE RX TO R0
$F70B: $85 $01        sta $01                      STA   R0H
$F70D: $60            rts                          RTS
$F70E: $A5 $00        lda $00             ST       LDA   R0L
$F710: $95 $00        sta $00,x                    STA   R0L,X      ;MOVE R0 TO RX
$F712: $A5 $01        lda $01                      LDA   R0H
$F714: $95 $01        sta $01,x                    STA   R0H,X
$F716: $60            rts                          RTS
$F717: $A5 $00        lda $00             STAT     LDA   R0L
$F719: $81 $00        sta ($00,x)         STAT2    STA   (R0L,X)    ;STORE BYTE INDIRECT
$F71B: $A0 $00        ldy #$00                     LDY   #$0
$F71D: $84 $1D        sty $1D             STAT3    STY   R14H       ;INDICATE R0 IS RESULT NEG
$F71F: $F6 $00        inc $00,x           INR      INC   R0L,X
$F721: $D0 $02        bne $F725                    BNE   INR2       ;INCR RX
$F723: $F6 $01        inc $01,x                    INC   R0H,X
$F725: $60            rts                 INR2     RTS
$F726: $A1 $00        lda ($00,x)         LDAT     LDA   (R0L,X)    ;LOAD INDIRECT (RX)
$F728: $85 $00        sta $00                      STA   R0L        ;TO R0
$F72A: $A0 $00        ldy #$00                     LDY   #$0
$F72C: $84 $01        sty $01                      STY   R0H        ;ZERO HIGH-ORDER R0 BYTE
$F72E: $F0 $ED        beq $F71D                    BEQ   STAT3      ;ALWAYS TAKEN
$F730: $A0 $00        ldy #$00            POP      LDY   #$0        ;HIGH ORDER BYTE = 0
$F732: $F0 $06        beq $F73A                    BEQ   POP2       ;ALWAYS TAKEN
$F734: $20 $66 $F7    jsr $F766           POPD     JSR   DCR        ;DECR RX
$F737: $A1 $00        lda ($00,x)                  LDA   (R0L,X)    ;POP HIGH ORDER BYTE @RX
$F739: $A8            tay                          TAY              ;SAVE IN Y-REG
$F73A: $20 $66 $F7    jsr $F766           POP2     JSR   DCR        ;DECR RX
$F73D: $A1 $00        lda ($00,x)                  LDA   (R0L,X)    ;LOW-ORDER BYTE
$F73F: $85 $00        sta $00                      STA   R0L        ;TO R0
$F741: $84 $01        sty $01                      STY   R0H
$F743: $A0 $00        ldy #$00            POP3     LDY   #$0        ;INDICATE R0 AS LAST RESULT REG
$F745: $84 $1D        sty $1D                      STY   R14H
$F747: $60            rts                          RTS
$F748: $20 $26 $F7    jsr $F726           LDDAT    JSR   LDAT       ;LOW-ORDER BYTE TO R0, INCR RX
$F74B: $A1 $00        lda ($00,x)                  LDA   (R0L,X)    ;HIGH-ORDER BYTE TO R0
$F74D: $85 $01        sta $01                      STA   R0H
$F74F: $4C $1F $F7    jmp $F71F                    JMP   INR        ;INCR RX
$F752: $20 $17 $F7    jsr $F717           STDAT    JSR   STAT       ;STORE INDIRECT LOW-ORDER
$F755: $A5 $01        lda $01                      LDA   R0H        ;BYTE AND INCR RX.  THEN
$F757: $81 $00        sta ($00,x)                  STA   (R0L,X)    ;STORE HIGH-ORDER BYTE.
$F759: $4C $1F $F7    jmp $F71F                    JMP   INR        ;INCR RX AND RETURN
$F75C: $20 $66 $F7    jsr $F766           STPAT    JSR   DCR        ;DECR RX
$F75F: $A5 $00        lda $00                      LDA   R0L
$F761: $81 $00        sta ($00,x)                  STA   (R0L,X)    ;STORE R0 LOW BYTE @RX
$F763: $4C $43 $F7    jmp $F743                    JMP   POP3       ;INDICATE R0 AS LAST RSLT REG
$F766: $B5 $00        lda $00,x           DCR      LDA   R0L,X
$F768: $D0 $02        bne $F76C                    BNE   DCR2       ;DECR RX
$F76A: $D6 $01        dec $01,x                    DEC   R0H,X
$F76C: $D6 $00        dec $00,x           DCR2     DEC   R0L,X
$F76E: $60            rts                          RTS
$F76F: $A0 $00        ldy #$00            SUB      LDY   #$0        ;RESULT TO R0
$F771: $38            sec                 CPR      SEC              ;NOTE Y-REG = 13*2 FOR CPR
$F772: $A5 $00        lda $00                      LDA   R0L
$F774: $F5 $00        sbc $00,x                    SBC   R0L,X
$F776: $99 $00 $00    sta $0000,y                  STA   R0L,Y      ;R0-RX TO RY
$F779: $A5 $01        lda $01                      LDA   R0H
$F77B: $F5 $01        sbc $01,x                    SBC   R0H,X
$F77D: $99 $01 $00    sta $0001,y         SUB2     STA   R0H,Y
$F780: $98            tya                          TYA              ;LAST RESULT REG*2
$F781: $69 $00        adc #$00                     ADC   #$0        ;CARRY TO LSB
$F783: $85 $1D        sta $1D                      STA   R14H
$F785: $60            rts                          RTS
$F786: $A5 $00        lda $00             ADD      LDA   R0L
$F788: $75 $00        adc $00,x                    ADC   R0L,X
$F78A: $85 $00        sta $00                      STA   R0L        ;R0+RX TO R0
$F78C: $A5 $01        lda $01                      LDA   R0H
$F78E: $75 $01        adc $01,x                    ADC   R0H,X
$F790: $A0 $00        ldy #$00                     LDY   #$0        ;R0 FOR RESULT
$F792: $F0 $E9        beq $F77D                    BEQ   SUB2       ;FINISH ADD
$F794: $A5 $1E        lda $1E             BS       LDA   R15L       ;NOTE X-REG IS 12*2!
$F796: $20 $19 $F7    jsr $F719                    JSR   STAT2      ;PUSH LOW PC BYTE VIA R12
$F799: $A5 $1F        lda $1F                      LDA   R15H
$F79B: $20 $19 $F7    jsr $F719                    JSR   STAT2      ;PUSH HIGH-ORDER PC BYTE
$F79E: $18            clc                 BR       CLC
$F79F: $B0 $0E        bcs $F7AF           BNC      BCS   BNC2       ;NO CARRY TEST
$F7A1: $B1 $1E        lda ($1E),y         BR1      LDA   (R15L),Y   ;DISPLACEMENT BYTE
$F7A3: $10 $01        bpl $F7A6                    BPL   BR2
$F7A5: $88            dey                          DEY
$F7A6: $65 $1E        adc $1E             BR2      ADC   R15L       ;ADD TO PC
$F7A8: $85 $1E        sta $1E                      STA   R15L
$F7AA: $98            tya                          TYA
$F7AB: $65 $1F        adc $1F                      ADC   R15H
$F7AD: $85 $1F        sta $1F                      STA   R15H
$F7AF: $60            rts                 BNC2     RTS
$F7B0: $B0 $EC        bcs $F79E           BC       BCS   BR
$F7B2: $60            rts                          RTS
$F7B3: $0A            asl                 BP       ASL              ;DOUBLE RESULT-REG INDEX
$F7B4: $AA            tax                          TAX              ;TO X REG FOR INDEXING
$F7B5: $B5 $01        lda $01,x                    LDA   R0H,X      ;TEST FOR PLUS
$F7B7: $10 $E8        bpl $F7A1                    BPL   BR1        ;BRANCH IF SO
$F7B9: $60            rts                          RTS
$F7BA: $0A            asl                 BM       ASL              ;DOUBLE RESULT-REG INDEX
$F7BB: $AA            tax                          TAX
$F7BC: $B5 $01        lda $01,x                    LDA   R0H,X      ;TEST FOR MINUS
$F7BE: $30 $E1        bmi $F7A1                    BMI   BR1
$F7C0: $60            rts                          RTS
$F7C1: $0A            asl                 BZ       ASL              ;DOUBLE RESULT-REG INDEX
$F7C2: $AA            tax                          TAX
$F7C3: $B5 $00        lda $00,x                    LDA   R0L,X      ;TEST FOR ZERO
$F7C5: $15 $01        ora $01,x                    ORA   R0H,X      ;(BOTH BYTES)
$F7C7: $F0 $D8        beq $F7A1                    BEQ   BR1        ;BRANCH IF SO
$F7C9: $60            rts                          RTS
$F7CA: $0A            asl                 BNZ      ASL              ;DOUBLE RESULT-REG INDEX
$F7CB: $AA            tax                          TAX
$F7CC: $B5 $00        lda $00,x                    LDA   R0L,X      ;TEST FOR NON-ZERO
$F7CE: $15 $01        ora $01,x                    ORA   R0H,X      ;(BOTH BYTES)
$F7D0: $D0 $CF        bne $F7A1                    BNE   BR1        ;BRANCH IF SO
$F7D2: $60            rts                          RTS
$F7D3: $0A            asl                 BM1      ASL              ;DOUBLE RESULT-REG INDEX
$F7D4: $AA            tax                          TAX
$F7D5: $B5 $00        lda $00,x                    LDA   R0L,X      ;CHECK BOTH BYTES
$F7D7: $35 $01        and $01,x                    AND   R0H,X      ;FOR $FF (MINUS 1)
$F7D9: $49 $FF        eor #$FF                     EOR   #$FF
$F7DB: $F0 $C4        beq $F7A1                    BEQ   BR1        ;BRANCH IF SO
$F7DD: $60            rts                          RTS
$F7DE: $0A            asl                 BNM1     ASL              ;DOUBLE RESULT-REG INDEX
$F7DF: $AA            tax                          TAX
$F7E0: $B5 $00        lda $00,x                    LDA   R0L,X
$F7E2: $35 $01        and $01,x                    AND   R0H,X      ;CHECK BOTH BYTES FOR NO $FF
$F7E4: $49 $FF        eor #$FF                     EOR   #$FF
$F7E6: $D0 $B9        bne $F7A1                    BNE   BR1        ;BRANCH IF NOT MINUS 1
$F7E8: $60            rts                 NUL      RTS
$F7E9: $A2 $18        ldx #$18            RS       LDX   #$18       ;12*2 FOR R12 AS STACK POINTER
$F7EB: $20 $66 $F7    jsr $F766                    JSR   DCR        ;DECR STACK POINTER
$F7EE: $A1 $00        lda ($00,x)                  LDA   (R0L,X)    ;POP HIGH RETURN ADDRESS TO PC
$F7F0: $85 $1F        sta $1F                      STA   R15H
$F7F2: $20 $66 $F7    jsr $F766                    JSR   DCR        ;SAME FOR LOW-ORDER BYTE
$F7F5: $A1 $00        lda ($00,x)                  LDA   (R0L,X)
$F7F7: $85 $1E        sta $1E                      STA   R15L
$F7F9: $60            rts                          RTS
$F7FA: $4C $C7 $F6    jmp $F6C7           RTN      JMP   RTNZ
                                          ASAVE   .EQU $45
                                          XSAVE   .EQU $46
                                          YSAVE   .EQU $47
                                          PSAVE   .EQU $48
                                          SAVE
$F7FD: $85 $45        sta $45                     STA ASAVE
$F7FF: $86 $46        stx $46                     STX XSAVE           ;SAVE 6502 CONTENTS *
$F801: $84 $47        sty $47                     STY YSAVE
$F803: $08            php                         PHP
$F804: $68            pla                         PLA
$F805: $85 $48        sta $48                     STA PSAVE
$F807: $60            rts                         RTS
                                          RESTORE
$F808: $A5 $48        lda $48                     LDA PSAVE
$F80A: $48            pha                         PHA
$F80B: $A5 $45        lda $45                     LDA ASAVE
$F80D: $A6 $46        ldx $46                     LDX XSAVE          ; RESTORE 6502 REG CONTENTS
$F80F: $A4 $47        ldy $47                     LDY YSAVE
$F811: $28            plp                         PLP
$F812: $60            rts                         RTS
