It is currently Mon May 13, 2024 7:58 pm
 Post subject: Wasting time
PostPosted: Sun Nov 05, 2023 7:48 am
I keep getting cycle times for short delay wrong. So I finally went for some macros and helper subroutines. Certainly done thousands of times before. Perhaps useful, perhaps incorrect, just let me know ;-)
edit:
;   nop.inc
;   remarks:
;       - nop1 is possible on a 65c02 using unused opcodes
;         (see http://www.6502.org/tutorials/65c02opcodes.html)
.macro nop2
    nop                     ; 2
.endmacro
.macro nop3
    jmp *+3                 ; 3
.endmacro
.macro nop4
    nop                     ; 2
    nop                     ; 2
.endmacro
.macro nop5
    nop                     ; 2
    jmp *+3                 ; 3
.endmacro
.macro nop6
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
.endmacro
.macro nop7
    php                     ; 3
    plp                     ; 4
.endmacro
.macro nop8
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
.endmacro
.macro nop9
    php                     ; 3
    plp                     ; 4
    nop                     ; 2
.endmacro
.macro nop10
    php                     ; 3
    bit tmp0                ; 3
    plp                     ; 4
.endmacro
.macro nop11
    php                     ; 3
    nop                     ; 2
    nop                     ; 2
    plp                     ; 4
.endmacro
.macro nop12
    jsr _nop12
.endmacro
.macro nop13
    php                     ; 3
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
    plp                     ; 4
.endmacro
.macro nop14
    jsr _nop14
.endmacro
.macro nop15
    php                     ; 3
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
    nop                     ; 2
    plp                     ; 4
.endmacro
.macro nop16
    jsr _nop16
.endmacro
.macro nop17
    php                     ; 3
    plp                     ; 4
    php                     ; 3
    bit tmp0                ; 3
    plp                     ; 4
.endmacro
.macro nop18
    jsr _nop18
.endmacro
.macro nop19
    jsr _nop19
.endmacro
.macro nop20
    jsr _nop20
.endmacro
;   nop.s
_nop20:
    nop                     ; 2
_nop18:
    nop                     ; 2
_nop16:
    nop                     ; 2
_nop14:
    nop                     ; 2
_nop12:
    rts                     ; 6 + 6
_nop19:
    php                     ; 3
    plp                     ; 4
    rts                     ; 6 + 6
;    delay.s
;   nice hack, changes N, Z and C
;   credits:
;       - https://www.pagetable.com/?p=669
_delay20:
    .byte $c9               ; 2     cmp #
_delay19:
    .byte $c9               ; 2     cmp #
_delay18:
    .byte $c9               ; 2     cmp #
_delay17:
    .byte $c9               ; 2     cmp #
_delay16:
    .byte $c9               ; 2     cmp #
_delay15:
    .byte $c5               ; 3     cmp zp
    nop                     ; 2
    rts                     ; 6 + 6
 Post subject: Re: Wasting time
PostPosted: Sun Nov 05, 2023 8:24 am
For longer delays, see Bruce's ingenious one at viewtopic.php?p=92070#p92070 .
PostPosted: Sun Nov 05, 2023 9:01 am
Amazing!
PostPosted: Sun Nov 05, 2023 10:54 am
For extra-long time wasting, I've been using the following implementation: https://github.com/bbbradsmith/6502vdelay - it's pretty accurate, but at some point I felt it would be better to redesign my code to use VIA timers so that my MPU can do something meaningful until the interval passes. :)
/Andrew
PostPosted: Sun Nov 05, 2023 10:27 pm
For accurate delays, reference to a hardware timer is better.  If you have a VIA in your system, you have two timers at your disposal with potentially sub-microsecond resolution, and interrupt capabilities.
PostPosted: Mon Nov 06, 2023 6:11 am
Many thanks to everyone for the good advice! I have edited the post accordingly.
PostPosted: Mon Nov 06, 2023 8:17 am
Here's an untested 65C02 "cycle-accurate" delay sub-system I'd like to use for serial protocol experiments. The minimum delay is 24 cycles and you can adjust the upper limit by changing the number of cycles used in the timing loop (the 'dloop' constant). Determine the loop size by multiplying the largest delay you require (in microseconds) by the clock (1, 2, 3, 4, 8, etc.) then divide by 65536. Use the integer result + 1 for the 'dloop' value.
Cheerful regards, Mike
;    file: serial_test.s                                      ~
;  author: Mike McLaren, K8LH                                 ~
;    date: 06-Nov-23 (last rev 09-Nov-23)                     ~
;     asm: CA65 v2.13.3                                       ~
.debuginfo +
.setcpu "65C02"
;  65C02 delayCy() sub-system macro inserts 3 instructions    ~
;  and calls the 'uloop' 16-bit counter subroutine.           ~
;  24 cycles minimum to dloop*65536+23 cycles maximum.        ~
.define cyc .byte $03       ; new 65C02 single-cycle opcode
clock   := 8                ; 1, 2, 3, 4, 8, etc. (clock)
usecs   := clock            ; cycles/microsecond multiplier
msecs   := clock*1000       ; cycles/millisecond multiplier
dloop   := 13               ; timing loop size (minimum 9)
.macro  delayCy cycles
       .if (cycles < 24) || (cycles > dloop*65536+23)
         .error "delayCy() range error"
       .endif
        lda #>(((cycles-24)/dloop)+1).mod 256 ;             (2)
        ldy #<(((cycles-24)/dloop)+1).mod 256 ;             (2)
        jsr uloop-((cycles-24).mod dloop)     ;             (6)
.endmac
.org $F000
;  example delayCy() code
port_b  := $6100
start:
        delayCy(100*msecs)  ; delay 100-msecs
test2:
        delayCy(8*usecs-13) ; 8-usecs minus 13 cycles
        lda port_b          ;                               (4)
        eor #%00000001      ; toggle b0 bit                 (2)
        sta port_b          ; precise 125-kHz intervals     (4)
        bra test2           ;                               (3)
;  65C02 delayCy() sub-system 16-bit counter subroutine       ~
       .repeat (dloop-1)    ; insert all (cycles-24)%dloop
        cyc                 ; single-cycle entry points
       .endrep              ;
;       cyc                 ; (cycles-24)%dloop == 8 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 7 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 6 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 5 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 4 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 3 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 2 entry  (1)
;       cyc                 ; (cycles-24)%dloop == 1 entry  (1)
uloop:
        dey                 ; decrement 16-bit lo byte      (2)
        bne uloop-dloop+5   ; zero? no, branch, else        (2)(3)
        dec A               ; decrement 16-bit hi byte      (2)
        bne uloop-dloop+9   ; zero? no, branch, else        (2)(3)
        rts                 ; exit                          (6)
;  alternative: Bruce Clark's single-loop 16-bit counter
        cpy #1              ; set or clear carry            (2)
        dey                 ; decrement lo byte             (2)
        sbc #0              ; decrement hi byte, or not     (2)
        bcs uloop-dloop+9   ; done? no, branch, else        (2)(3)
        rts                 ; exit                          (6)
.segment "VECTS"
.org $FFFA
       .word start          ; NMI
       .word start          ; RESET
       .word start          ; IRQ
PostPosted: Mon Nov 06, 2023 9:09 am
Dear Mike, I have not used the Kowalski Simulator yet. But I have had good experiences with a simple logic analyzer to check the serial timing. If I have understood your setup correctly, you have full control over the external clock on your hardware and could perhaps do the analysis via a free AVR port?
PostPosted: Tue Nov 07, 2023 11:59 pm
I took a stab at a "cycle accurate" short delay macro below (still using 65C02 single-cycle nop's). I wonder what a "cycle-accurate" version using straight 6502 code (minus the impossible 1-cycle delay) would look like?
;    file: serial_test_2.s                                    ~
;    date: 07-Nov-23                                          ~
.debuginfo +
.setcpu "65C02"
;  65C02 "short delay" macro generates 0 to 9 bytes per call  ~
;  and produces 'cycle-accurate' delays of 0 to 1285 cycles.  ~
;  1285.00-usecs @  1-MHz      () destroys X register         ~
;   642.50-usecs @  2-MHz                                     ~
;   321.25-usecs @  4-MHz                                     ~
clock   := 2                ; 1, 2, 4, 8, 16 (MHz clock)
.macro  delay cycles
       .local loop
       .if (cycles < 0) || (cycles > 1285)
         .error "delay() range error"
       .endif
       .if (cycles > 5)
          ldx #(((cycles-1)/5).mod 256)  ;                  (2)
          loop:
            dex             ;                               (2)
            bne loop        ;                               (2)(3)
         .repeat ((cycles-1) .mod 5)
            cyc             ; 65C02 single-cycle 'nop'      (1)
         .endrep            ;
       .else
         .repeat (cycles)
         .endrep
       .endif
.endmac
.org $F000
;   in-line short delay code examples
port_b  := $6100
start:
        delay(100*usecs)    ; 100-usecs
        delay(32)           ; 32 cycles
test2:
        delay(20*usecs-13)  ; 20-usecs minus 13 cycles
        lda port_b          ;                               (4)
        sta port_b          ; precise 50-kHz intervals      (4)
        bra test2           ;                               (3)
.segment "VECTS"
.org $FFFA
        .word start         ; NMI
        .word start         ; RESET
        .word start         ; IRQ
PostPosted: Wed Nov 08, 2023 12:02 pm
Hi Mike, I was pointed to https://bisqwit.iki.fi/utils/nesdelay.php (see post #1). It looks to me as if there is already an optimal solution for every kind of delay. I have therefore switched to other ways of wasting time in the meantime ;-)
Just a small note: It might be useful to use a separate macro for 65c02 single-cycle-nop and make it configurable. For example, my system uses $03 to access the extended memory.
PostPosted: Wed Nov 08, 2023 1:02 pm
That site is pretty neat but it gave me a macro with over 113,000 lines.
PostPosted: Wed Nov 08, 2023 6:17 pm
This is what happens when computers write code instead of humans :D
PostPosted: Wed Nov 08, 2023 7:08 pm
...or the code is written by humans who don’t know assembly language.  :shock:
Users browsing this forum: LVS12122 and 6 guests
