It is currently Fri May 10, 2024 4:44 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Nov 09, 2023 4:02 pm
gfoot wrote:
Cookie13! wrote:
This also does nothing. Totally confused.
I know it's probably just a careless idiom, but note that this is almost certainly not true! It is quite hard to get a 6502 to do nothing, unless you stop its clock. It is probably doing something, but not what you expect, and it is important to find ways to determine what that is.
A good way to do that is to use a bus monitor. If you can slow your clock way down you can use an Arduino the way Ben Eater does. But better - and not too expensive - is to use an FX2 dev board as a logic analyzer and feed its capture file to Hoglet's 6502 decoder software. Here's a recent thread about that: viewtopic.php?f=12&t=7710
If your DMM has a frequency counter (My Aneng 8008 does and it's a pretty cheap DMM) you could also try setting up the VIA as a frequency generator:
    lda     #$FF
    sta     DDRA        ; Set PORTA to OUTPUT
forever:
    inc     PORTA
    bra     forever     ; or 'jmp     forever' if you're using an NMOS CPU
If your VIA is working you should see 8 square waves on the PORTA pins, each half the frequency of the previous one.
PostPosted: Fri Nov 10, 2023 4:42 pm
Hi All, thanks for all the great inputs. As several have pointed out it is probably a connection issue. As it was always not (or only partially) working subroutines this pointed to the RAM. I found OE which should have been connected to A14 out by one hole so connected to nothing. Now it all works. Thanks once again. I'm sure I will be back with more questions as I proceed.
