This is tougher than it looks because on some platforms (VIC-20, PET, BBC Micro) the original OS is still present; and at least on the VIC-20 and PET the OS vectors are somewhere really awkward and it was easier to just turn interrupts off and ignore them.
Is it? On the C64 (and therefore presumably the VIC-20 and the PET), the IRQ routine saves the registers on the stack and then checks to see if the BRK flag is set. If so, it jumps through an indirect vector at $0316. If not (a normal IRQ), through an indirect vector at $0314.
When I did something like that I pointed the indirect vector at $0316 to point to my BRK routine. Then replaced whatever instruction where I wanted to look at the registers with a BRK. So all instructions could be replaced by one byte.
When I first read your post I was wondering if you planned to replace your three-byte sequence with three NOPs once you were finished with them.
You could, I suppose, write any instruction you wanted to replace with a macro and use that. The macro would check a flag to see if this was a replaceable instruction and if so, write your three-byte sequence. If not, it would write the original instruction. That way it wouldn't matter how long what was being replaced was, though you might have to re-assemble your code every time you set or cleared a "check this" flag.
