It is currently Mon Sep 23, 2024 12:25 am
 Post subject: GWMON-65 Small Monitor
PostPosted: Tue Jun 14, 2022 7:12 pm
I think it's finally ready to be poked at:
https://github.com/glitchwrks/gwmon-65
This is a monitor that follows the same command syntax and input/output formatting as GWMON-80, our small monitor for 8080 and compatible systems. It's not really a straight-across port as parts were rewritten to take advantage of the 6502, rather than trying to cram 8080 patterns into 6502 syntax.
The monitor has four basic functions: Dump memory, Edit memory, Go to address, and Load Intel HEX data. The README covers command syntax. The D command output is parseable by SRecord's -hexdump option.
GWMON-65 SM with Motorola 6850 I/O initialization and reset/NMI/IRQ vectors fits in 512 bytes, which means it'll work with very old systems like the Ohio Scientific 400 board, which uses two 1702A 256-byte EPROMs.
Like GWMON-80, GWMON-65 is modular, to make it easy to create new customizations for systems.
Feedback appreciated!
PostPosted: Sun Feb 05, 2023 8:11 pm
Congrats and thanks
