It is currently Thu May 09, 2024 10:27 am
PostPosted: Fri Sep 09, 2022 8:58 pm
I'm diving in, once again, to an old project: disassembling and documenting the "KVOS" I found in the ROMs of a KIM-1 I bought several years ago. More information: https://retroconnector.com/bdc-6500-computer-kim-1/
I've learned a great deal since I last left it, and now I've been able to decipher enough of the boot process to work out what I think is the routine for loading a program from tape (maybe paper tape?)
This code looks like it waits for a header like "XXXX"+efabcd
The initial loop waits for an ASCII "X" 0x58, then the first three characters after X are ignored.
the e f bytes are stored in $04, $05
a,b,c,d bytes are stored in $00, $01, $02, $03
Byte c ($02) is subtracted from 0, and stored back in $02
Byte d ($03) is subtracted from 0, and stored back in $03
It then loops with a series of bytes loaded from the 6522, stored at address set in $00,$01. Loops until cd bytes are read.
When it's done loading, jumps to address in $04,$05
In short: "load the program with entry point EF, starting at AB, length CD"
FC1A           cld                    ;  D8
FC1B           sei                    ;  78
FC1C           ldx     #$FF           ;  A2 FF
FC1E           txs                    ;  9A
FC1F           lda     #$00           ;  A9 00
FC21           sta     6522-DDRA      ;  8D 83 15
FC24           lda     6522-PCR       ;  AD 8C 15
FC27           and     #$F0           ;  29 F0
FC29           ora     $0E            ;  05 0E
FC2B           sta     6522-PCR       ;  8D 8C 15
FC2E   LFC2E:  jsr     WAITFORIO      ;  20 7F FC
FC31           cmp     #$58           ;  C9 58
FC33           bne     LFC2E          ;  D0 F9
FC35           jsr     WAITFORIO      ;  20 7F FC
FC38           jsr     WAITFORIO      ;  20 7F FC
FC3B   LFC3B:  jsr     WAITFORIO      ;  20 7F FC
FC3E           jsr     WAITFORIO      ;  20 7F FC
FC41           sta     L0004          ;  85 04
FC43           jsr     WAITFORIO      ;  20 7F FC
FC46           sta     $05            ;  85 05
FC48           jsr     WAITFORIO      ;  20 7F FC
FC4B           sta     $00            ;  85 00
FC4D           jsr     WAITFORIO      ;  20 7F FC
FC50           sta     $01            ;  85 01
FC52           jsr     WAITFORIO      ;  20 7F FC
FC55           sta     $02            ;  85 02
FC57           jsr     WAITFORIO      ;  20 7F FC
FC5A           sta     $03            ;  85 03
FC5C           ldx     #$00           ;  A2 00
FC5E           txa                    ;  8A
FC5F   LFC5F:  sec                    ;  38
FC60           sbc     $02            ;  E5 02
FC62           sta     $02            ;  85 02
FC64           txa                    ;  8A
FC65           sbc     $03            ;  E5 03
FC67           sta     $03            ;  85 03
FC69   LFC69:  jsr     WAITFORIO      ;  20 7F FC
FC6C           sta     ($00,x)        ;  81 00
FC6E           inc     $00            ;  E6 00
FC70           bne     LFC74          ;  D0 02
FC72           inc     $01            ;  E6 01
FC74   LFC74:  inc     $02            ;  E6 02
FC76           bne     LFC69          ;  D0 F1
FC78           inc     $03            ;  E6 03
FC7A           bne     LFC69          ;  D0 ED
FC7C           jmp     (L0004)        ;  6C 04 00
; LOOPS UNTIL INPUT ON 6522. INTERRUPT FLAG BIT 1 SET ON IO AT 6522 PORTA
WAITFORIO:
FC7F        lda     6522-IFR       ;  AD 8D 15
FC82        and     #$02           ;  29 02
FC84        beq     WAITFORIO      ;  F0 F9
FC86        lda     6522-INPUTA    ;  AD 81 15
FC89        pha                    ;  48
FC8A        lda     6522-PCR       ;  AD 8C 15
FC8D        and     #$F0           ;  29 F0
FC8F        ora     #$0C           ;  09 0C
FC91        sta     6522-PCR       ;  8D 8C 15
FC94        ora     #$0E           ;  09 0E
FC96        sta     6522-PCR       ;  8D 8C 15
FC99        pla                    ;  68
FC9A        rts                    ;  60
Does this format sound familiar to anyone - 10-bytes of header starting with X, and finishing with three 2-byte words defining where and how much to load? Would programs have been stored on paper tape? Or sent via a serial terminal? Any pointers that might help illuminate the process would be greatly appreciated.
PostPosted: Sat Sep 10, 2022 7:08 am
It's new to me, but interesting to see it. For example, what the intended role of the two ignored bytes might be - I'm going to guess a checksum. Also the fact that it's dealing with raw binary, not hex. And indeed, booting over a parallel port rather than a serial one...
8 hole paper tape does seem most likely, I think. And the sprocket holes act as a timing source, so it can (presumably) readily be hooked up as a data byte plus strobe.
