It is currently Sun Nov 24, 2024 10:21 pm
PostPosted: Mon May 23, 2022 5:57 pm
How do I programmatically trigger the RESET vector, and bring a 6502 CPU back to the state it was when it was first turning on?
Last edited by jeffythedragonslayer on Sat Aug 20, 2022 7:40 pm, edited 1 time in total.
PostPosted: Mon May 23, 2022 6:01 pm
The nearest you can do is to execute:
JMP (&FFFC)
but this only resets the CPU, not any peripherals, so it's not really the same as a power-up reset.
Dave
PostPosted: Mon May 23, 2022 6:39 pm
If you'd like to trigger a hardware reset, you can wire up a pin from your VIA to the reset pin, being careful to never set it as output high (or preferably add a diode with its cathode towards the VIA for safety). Again that's not like cycling the power but it will reset more peripherals
BB816 Computer YouTube series
PostPosted: Mon May 23, 2022 7:01 pm
For interest, there are threads over on stardot explaining the rather different situations of the BBC Micro and Acorn's Electron, with respect to simulating a cold boot:
How to force a hard reset (CTRL+BREAK)?
Simulate a cold boot on the Electron
In effect, there are two challenges: resetting all the system state which would have been reset by powering up, and getting the OS to do the things it would do at power up.
PostPosted: Thu Jul 21, 2022 11:20 pm
Thanks, I was able to code up a soft reset proc to reboot the CPU with the JMP instruction.
