It is currently Wed May 08, 2024 7:17 pm
PostPosted: Sun Jun 12, 2022 7:22 pm
Hi there, can someone identify where this code snippet came from? Is it public domain? (It didn't look easy to contact Frantic through codebase64 and I'm not part of the C64 scene).
https://codebase64.org/doku.php?id=base ... t&do=admin
It apparently was originally posted here on 6502.org
Could it be the routine BigDumbDinosaur wrote in 1990? (viewtopic.php?f=2&t=6838#p88009)
PostPosted: Sun Jun 12, 2022 8:09 pm
Klaus posts a similar bit of code here, adapted from a reference page here, where "Greg" exhibits a routine derived from one in "the 6502 Software Design book by Leo J. Scanlon" (a 1980 book, archived here.)
PostPosted: Sun Jun 12, 2022 8:36 pm
It looks similar to code presented by dclxvi back in 2005 in this post.
PostPosted: Sun Jun 12, 2022 9:11 pm
Hmm, that code uses PHA and PLA which the others don't...
PostPosted: Sun Jun 12, 2022 9:15 pm
It's fairly much generic and very similar to the initial multiplication code I used in my Ruby BCPL code (32x32 bit multiply to get a 64-bit result - it's extendable with ease)
This is where I got my initial code version from: https://llx.com/Neil/a2/mult.html (about half way down the page) which is more or less the same as that.
PostPosted: Sun Jun 12, 2022 9:30 pm
Certainly the plan of attack is fairly generic. But I see Neil's version uses TAY and TYA - presumably much like Bruce's PHA and PLA - which the others don't.
Also, at the second label, some of the code uses LSR and some uses ROR for the first shift. And some will store after that first shift while others don't store until just before the final return.
So at a forensic level, there are some small choices which are being made differently.
PostPosted: Sun Jun 12, 2022 11:19 pm
Thanks. I had seen http://www.6502.org/source/integers/32muldiv.htm before but the way the comment at the top of the snippet on codebase64.org was worded, it sounded like there was a 16-bit multiply with 32-bit product on this site somewhere it was copied from. Based on the similar label names, variable names, and code structure, I believe this codebase64 snippet is a modified version of the 32-bit multiply with 64-bit product by Greg. I have also ordered the Scanlon book to see what the original routine looks like.
A google search of "site:http://6502.org/source/ license" came up with zilch for me, and only one page of results for "site:http://6502.org/source/ copyright" so it is not always easy to tell if something in the source code repository is an orphaned work or public domain or what. Have you considered having adding a note at the top of that page about suggesting licenses when people email contributions? Github does a good job of suggesting people add licenses to their repository for example, so it's usually pretty easy for me to tell how I can use a repo.
Users browsing this forum: hoglet and 5 guests
