It is currently Sat Nov 23, 2024 2:41 pm
PostPosted: Thu Jun 02, 2022 6:56 am
I'm confused whether to think of the 65816's A accumulator as changing in width along with the m flag (because LDA is how you load both 8 and 16 bits values into the accumulator) or A as always being 8 bits (because of the XBA instruction). How do you think of A's width?
I'd probably appreciate an assembler that understands LDC and STC as mnemonics so I could make this a little more clear in my mind; the assembler would bark if you try to use them in emulation mode (Rice's theorem notwithstanding, the assembler would have to rely on whether it thinks native or emulation mode is active). I do not know of a way to implement LDB and STB without clobbering the neighboring 8-bit A or adjacent byte. EDIT: thanks to oziphanto who just pointed out that XBA, LDA, XBA implements LDB.
PostPosted: Thu Jun 02, 2022 7:01 am
I think of A as operating either as 8 or 16 bits depending on M.
B can be thought of as the top half of the wide A, if you like. XBA is a special case! B isn't nearly as useful as I first thought it would be - it falls far far short of being a second accumulator.
PostPosted: Thu Jun 02, 2022 7:54 am
M changes "memory" mode to be 8 or 16 bits. The A register is considered "memory", so for me, it's variable width and matches memory load/stores (which makes sense).
One thing to watch out for is that if you are in 8-bit M mode and load a value (8-bits) into A then switch to 16-bit mode the A register is extended to 16-bits (as you might expect) by tagging on the B register - with whatever that contains which is in contrast with X mode as when you change that from 8 to 16-bits the top 8-bits of the new 16-bit index register is forced to zero.
My bugbear here is what I wish it were possible to do an 8-bit load while in 16-bit M mode which would force the top 8 bits to zero. Just like every other 16/32/64/ bit CPU I've used... But maybe that's just me and bytecode interpreters...
PostPosted: Thu Jun 02, 2022 8:37 am
I also think of A as having a variable width. For what I'm working on now, I figured out early on that it's easiest just to stay in 16-bit mode and only switch to 8-bit mode when needed and switched back immediately afterwards.
PostPosted: Thu Jun 02, 2022 9:32 am
That was my strategy for my (BCPL) bytecode interpreter, but that 16-bit fetch and subsequent AND #$00FF adds so many cycles to each bytecode fetch it measurably slows it down )-: (and switching to 8-bit mode here doesn't help either unless I could guarantee zero in the upper 8-bits)
PostPosted: Thu Jun 02, 2022 2:50 pm
Yes, I've had similar situations. This is where a few dedicated byte specific instructions would be helpful. I'm always looking for ways to handle byte level data 2 bytes at a time in 16-bit mode. For example I use the output_2ch routine below to output 2 characters at a time:
output_ch:      jmp put_c
output_2ch:     jsr output_ch
                xba
                jmp put_c
I use this when outputing null terminated ascii strings. That way I can stay in 16-bit mode and process the string a bit quicker than handling the characters one at a time. The only modification is that the string needs to be terminated with a null word to handle both odd and even length strings.
Of course, faster would be a dedicated low-level routine to handle string output as the put_c routine above calls a low-level ACIA routine that switches to 8-bit mode and back to 16-bit mode for each character. I might do this someday but my LCD can't keep up with the output as it is so it's not a high priority. On a side note: unfortunately you can't write 16-bit value to the 65C51 transmitter register because it will cause a programmed reset of the chip.
PostPosted: Fri Jun 03, 2022 3:00 am
That is what I did with my BIOS; I have a specific call for printing null-terminated strings, and it stays in 8-bit mode while doing it. My BIOS dispatches are via COP so it saves a lot of syscall overhead. Only part I don't like about it is that it's arguably not something the BIOS should be doing. Probably what I should do is replace this with multi-byte read/write calls that pass a buffer and number of bytes, then reimplement my current call as a library call on top of the multi-byte write.
PostPosted: Sat Jun 04, 2022 9:46 am
Using XBA, .B is useful as a temporary store when working with byte-sized data, e.g., as in this DUART driver code fragment:
03425  00D362  A1 24                  lda (siofif,x)        ;no, get datum from RHR  <———
03426  00D364  EB                     xba                   ;protect it for now <———
03427  00D365  B5 34                  lda sioputrx,x        ;get queue 'put' pointer <———
03428  00D367  1A                     inc                   ;bump it
03429  00D368  D5 2C                  cmp siogetrx,x        ;any room in queue?
03430  00D36A  F0 F0                  beq .0000020          ;no, discard datum
03431  ;
03432  00D36C  EB                     xba                   ;yes, recover datum &...  <———
03433  00D36D  81 34                  sta (sioputrx,x)      ;store in queue <———
XBA is also handy for reversing the endianess of a 16-bit value. Beyond that, you’re right: .B doesn't do much for you.
PostPosted: Mon Jun 06, 2022 5:44 pm
I found it useful to keep the M flag as 16 bit and the index registers in 8 bit mode for PLASMA. My byte code fetch/dispatch is:
        INY                     ; NEXTOP @ $F0
        LDX     $FFFF,Y         ; FETCHOP @ $F1, IP MAPS OVER $FFFF @ $F2
        JMP     (OPTBL,X)       ; OPIDX AND OPPAGE MAP OVER OPTBL
and runs out of zero page. Y is the interpreters instruction pointer (IP) offset. The IP+Y value gets renormalized during certain instructions' execution to keep it from overflowing. Also, the byte codes are even, so there is no requirement to shift the value but it does limit the number of byte codes to 128 with an 8 bit X register.
On occasion I do have to switch A to 8 bit mode, but at least it isn't every byte code fetch. Mixing accumulator/memory and index widths can limit the about of width flag thrashing with a little creativity.
PostPosted: Mon Jun 06, 2022 7:17 pm
        INY                     ; NEXTOP @ $F0
That's nice and simple. Hm.
I have a full compliment of 256 opcodes to deal with... I did try to work through scenarios where I could use an index register as the program counter, but didn't come up with anything useful, also keeping it in zero page and self-modifying the "PC" but it was also handy to have the VM's PC kept as a 32-bit register in zero page for various arithmetic operations - like jumps and so on.
This is the current dispatcher:
; Loop of the interpreter
        lda     [regPC]         ; Load 16-bit value                             (7)
        and     #$00FF          ; We only want 8-bits...                        (3)
        asl                     ; Double for indexing in 16-bit wide jump table (2)
        tax        (2)
; Increment the PC
        inc     regPC+0         ; Low word                                      (7)
        beq     incH1           ; 2 cycles + 1 when branch taken                (2)
        jmp     (opcodesLo,x)                                                   (6) = 29
incH1:  inc     regPC+2         ; Top word                                      (7)
        jmp     (opcodesLo,x)                                                   (6) = 37
This is a macro that's in-lined with every opcode the VM handles. It adds space but the cycles it saves are worth it. So 29 cycles or rarely 37 cycles overhead for every VM opcode that's executed.
PostPosted: Tue Jun 14, 2022 11:53 am
                xba
                jmp put_c
It is sometimes useful for a subroutine to jump into the body of itself. This is not a violation of structured programming single return statement:
                xba
output_ch:
put_c:
This is probably well known but I discovered it when trying to implement 8/16 bit types in SWEET16 on Z80 for CollapseOS. For the second time, I remembered why 8080 derivatives are awful and I abandoned it.
