It is currently Fri Nov 01, 2024 1:30 am
PostPosted: Mon May 02, 2022 7:29 pm
I thought I understood this, but I suspect something basic is tripping me up. I was under the impression that BCC could be used as a 'less than' operator and BCS as a 'more than'. But it's not working for me.
I'm trying to run a test to ensure that an input character is uppercase alpha (ASCII 65 to 90 inclusive). The code currently looks like this:
.read_filename_next_char
  lda STDIN_BUF,X           ; Get next byte from buffer
  inx
  beq read_filename_check   ; If a null (0), at end of input
  cmp #CHR_SPACE            ; If it's a space, ignore it & get next byte
  beq read_filename_next_char
  cmp #CHR_LINEEND          ; Same for linefeed
  cmp #65
  bcc read_filename_fail
  cmp #90
  bcs read_filename_fail
But when I use this, the code always routes to the read_filename_fail label - ie, the character always fails the tests. I know I'm probably doing something dumb, but I just can't see it.
I like it when things smoke.
BlogZolatron 64 project
PostPosted: Mon May 02, 2022 7:39 pm
is testing the Z frag from "inx", not "lda" ; this will miss the trailing null on a C string.
  cmp #65
will branch on unsigned < 'A' ; seems OK.
  cmp #90
will branch on unsigned >= 'Z'; did you mean cmp #'Z'+1 ?
PostPosted: Mon May 02, 2022 7:45 pm
I picked up on that immediately after posting!
leepivonka wrote:
  cmp #90
Yes, you're right. Here's an amended version:
  ldy #0                    ; Offset for where we're storing each byte
  beq read_filename_loop
  cmp #CHR_LINEEND
  cmp #65                  ; Acceptable values are 65-90 (A-Z)
  cmp #91
  sta STR_BUF,Y             ; Store in STR_BUF buffer
  iny                       ; Increment STR_BUF index
.read_filename_loop
  inx                       ; Increment input buffer index
  jmp read_filename_next_char
.read_filename_fail
PostPosted: Mon May 02, 2022 7:51 pm
Some assemblers give you
  BLT: <
  BGT: >
  BLE - <=
  BGE: >=
These are sometimes macros, sometimes pseudo ops..
With ca65 which I use if I
.macpack generic
then it gives me:
            .macro  add     Arg     ; add without carry
                    clc
                    adc     Arg
            .endmacro
            .macro  sub     Arg     ; subtract without borrow
                    sec
                    sbc     Arg
            .endmacro
            .macro  bge     Arg     ; branch on greater-than or equal
                    bcs     Arg
            .endmacro
            .macro  blt     Arg     ; branch on less-than
                    bcc     Arg
            .endmacro
            .macro  bgt     Arg     ; branch on greater-than
                    .local  L
                    beq     L
                    bcs     Arg
            L:
            .endmacro
            .macro  ble     Arg     ; branch on less-than or equal
                    beq     Arg
                    bcc     Arg
            .endmacro
            .macro  bnz     Arg     ; branch on not zero
                    bne     Arg
            .endmacro
            .macro  bze     Arg     ; branch on zero
                    beq     Arg
            .endmacro
Hope this is of some use...
PostPosted: Tue May 03, 2022 2:36 am
lda #A
cmp #B
bcc A_less_than_B
beq A_same_as_B
bne A_greater_than_B
That’s all there is to it.
PostPosted: Tue May 03, 2022 6:55 am
lda #A
cmp #B
bcc A_less_than_B
beq A_same_as_B
That’s what I always understood, which is why I’m confused about why it’s not working. But I think that misplaced INX is the problem. Without the error checking, this routine actually works. Or maybe that should be ‘works’.
Haven’t had the opportunity to check it yet, but what I think is happening is that the original routine is ignoring the null terminator and instead triggering when X rolls over. By this time, all kinds of random garbage has been copied into the STR_BUF buffer, with the final char unlikely to be in the range A-Z. Which is why the sanity check barfs.
This would also explain why a later check, on the size of Y (the length of the provided filename) is also failing to work as expected. And maybe another new problem with an entirely unrelated buffer getting corrupted. All from that one mistake (and a lack of bounds checking). I’ll give the fix a whirl later today.
[UPDATE] Yep, moving that INX solved all three problems!
PostPosted: Tue May 03, 2022 1:35 pm
As a fairly general rule, you should branch immediately after the comparison—no intermediate instructions between the comparison and the branch. The exceptions would be if you know for certain an intermediate operation will not affect the relevant flag(s) or if the comparison is being used because it affects the flags in a certain way in linear code. If the latter, you need to thoroughly comment the usage, since it may not be immediately obvious.
