It is currently Fri Nov 22, 2024 11:31 am
PostPosted: Tue Dec 28, 2021 4:24 am
Hello,
I have a small problem with the use of the VLINK. I hope someone can help me:
In the VIC-20 program source code, I am using the *=<expression> to define the base address for the code section (starts at $1001) and the character section (starts at $1C00):
*=$1001
; Code and data
*=$1C00
; Character RAM
When I am using VASM (oldstyle syntax module) to create a binary from assembler source code it all works fine and it produces the .prg file with:
    - Two bytes header
    - Followed by code section with the machine code and data
    - Followed by the area filled with zeros
    - Starting with the position $C02 (because of the 2 bytes header) in the file are appended custom characters.
However, when I use VASM to create the object file followed by calling the VLINK linker to create a binary the *=1$C00 is ignored and the character section starts immediately after the code section without the area filled with zeros, so the app does not work properly…
Please see attached image:
Broken external image link
https://gcdn.pbrd.co/images/rMtBoCi129Vg.png?o=1
Many thanks for your help
STeN
PostPosted: Thu Dec 30, 2021 4:33 pm
Because many object file formats do not store target addresses, when using a linker and relocatable object files, you usually specify the memory layout in a linker script. This is very flexible but a bit more effort. The oldstyle syntax module creates a new section for every org directive. A linker file for your case could look like this:
MEMORY
 ram : org = 0x1001, len=0x4000
SECTIONS
 code: { *(seg1001) } >ram
 fill: { .=.+0x1c00-0x1001-SIZEOF(code);}
 chars: { *(seg1c00) } >ram
The section names seg* are generated from the addresses. You could also use a named section, but then the code will not work without a linker.
I am not sure at the moment if it is also possible to have the oldstyle syntax module generate a single section with the gaps filled, eliminating the need for a linker script. I will check this with the author of that module.
Users browsing this forum: Google [Bot] and 13 guests
