; fast textmode putpixel
; (made for c64 but can be used anywhere)
; it's real fast but takes 50 bytes of zeropage
; for 25 columns screen
; -> good for demos ;-)
; how does it work:
; on zeropage there are 2byte columns' pointers
; and there is only Y index reg used to determine
; row of pixel
; just like STA ([column*2+zeropageptr]),y
; Written from scratch by Rafal Szyja , Poland
zeropage= 100 ; zeropage pointer for generating tables
_x= 251 ; x coordinate of
_y= 252 ; y
temp= 99 ; temporary storage
*= $1000
JSR gentab ; this is called only once for this routine
; by altering gentab you can for example make table
; for different screen posiotion and organization
; than c64's poweron default 40x25 @ 0400
; this is only testpiece - pixels are to be set somewhere else
; and then jump to setpix
LDA #0
STA _x
LDA #10
STA _y
; real start of routine
setpix
LDA _y
ASL
CLC ; y coor will be always < 128 so you can gain 2 cycles by deleting this line
ADC #100
sta dest+1 ; program automodification = faster operation
ldy _x
lda #255 ; just to test routine , there is actual pixelval
dest
STA ($00),y
rts
gentab ; generates tables with columns' values
LDA #$00 ; LSB of screen
LDX #$04 ; MSB of screen
LDY #0
loop
STA zeropage,y
INY
sta temp
txa
STa zeropage,y
lda temp
INY
CLC
ADC #40 ; 40 rows
BCC _a
INX
_a
CPY #50
BEQ stop
jmp loop
stop
RTS
and slower variation using only 4 zeropage registers (possibly only 2):
*= $1000
_x= 251 ; x
_y= 252 ; y
dyl = 253 ; destination lo
dyh = 254 ; hi
LDA #2
STA _y
LDA #2
sta _x
LDA #0
STA dyh
LDA _y
ASL ;A
ROL dyh
ASL ;a
ROL dyh
CLC
ADC _y
BCC x1
INC dyh
x1
ASL ;A
ROL dyh
ASL ;A
ROL dyh
ASL ;A
ROL dyh
STA dyl
CLC
LDA dyh
ADC #$04
STA dyh
LDY _x
LDA #160
STA (dyl),y
JMP *
owns 1xC128, 1x128D cr ,1xc64 (broken unfortunately) ,1xc64c ,2xc64g (one is broken) ,~4xc64e ,1x1541 ,1x1541-II ,1x1541C and some chips for those machines
www.vulture.c64.org
www.rafalszyja.republika.pl
