It is currently Sun Nov 24, 2024 12:23 am
PostPosted: Sat Mar 25, 2023 8:24 pm
on Hacker News. Here's the article, and here's the HN discussion. :)
Explaining my fast 6502 code generator
To learn how optimizing compilers are made, I built one targeting the 6502 architecture. In a bizarre twist, my compiler generates faster code than GCC, LLVM, and every other compiler I compared it to.
I reckon my compiler isn't doing more when it comes to high-level optimizations, so the gains must be from the code generation side. This makes sense, as most compilers are multi-target, with backends designed for modern RISC-like systems, not the ancient 6502. It doesn't matter how good GCC or LLVM's high-level optimizations are if they falter at the last leg of the race.
Still, my compiler also beats those designed for retro and embedded systems, like VBCC, SDCC, and KickC. For this reason, it seemed like a good idea to write about my technique.
PostPosted: Sat Mar 25, 2023 8:43 pm
Intersting stuff.
Just some random points:
  • It's a cross compiler.
  • It's not a C compiler, but a language with C-like features.
  • It won't work on a 65C02. (The compiler deliberately outputs "illegal" opcodes)
  • Seems to specifically target the NES platform, but I suspect that may be changeable by hacking the source code.
  • Er: Division is unsupported.
  • Looks like you can't do separate compilation, but you can compile several files at once - like concatenation, I think.
But it's nice to see something new. Maybe the existing C compiler people can look and adapt some of their stuff?
PostPosted: Sun Mar 26, 2023 3:42 am
I've found his write-up on how it's done, and the principles underneath enlightening and very useful.
For the past few years I've been writing a large 6502 application framework and a number of techniques used to squeeze out more performance mirror the ones he's described. He explains simply and concisely those concepts that I have been struggling with in frustration. A great find, Dr Jefyll!
PostPosted: Tue Mar 28, 2023 4:12 pm
I read that post and wondered if some of the later steps where the generated assembly is refined could be applied to hand-written assembly code. I have not been able to find the source code for the compiler though, and most of the algorithms in the post seem way above my head.
Anyone know if the source of this compiler is available? And what do you think about using these techniques to optimize existing assembly code?
Jonathan Foucher
Take a look at the Planck 6502 computer.
PostPosted: Tue Mar 28, 2023 5:51 pm
I think this is the source
https://github.com/pubby/nesfab
