It is currently Sat Nov 16, 2024 8:49 pm
Post new topic Reply to topic  [ 1 post ]
PostPosted: Thu Aug 18, 2005 10:48 am
; fast textmode putpixel
; (made for c64 but can be used anywhere)
; it's real fast but takes 50 bytes of zeropage
; for 25 columns screen
; -> good for demos ;-)
; how does it work:
; on zeropage there are 2byte columns' pointers
; and there is only Y index reg used to determine
; row of pixel
; just like STA ([column*2+zeropageptr]),y
; Written from scratch by Rafal Szyja , Poland
zeropage= 100 ; zeropage pointer for generating tables
_x= 251   ; x coordinate of
_y= 252   ; y
temp= 99   ; temporary storage
   *= $1000
   JSR gentab   ; this is called only once for this routine
         ; by altering gentab you can for example make table
         ; for different screen posiotion and organization
         ; than c64's poweron default 40x25 @ 0400
; this is only testpiece - pixels are to be set somewhere else
; and then jump to setpix
   LDA #0
   STA _x
   LDA #10
   STA _y
; real start of routine
setpix
   LDA _y
   ASL
   CLC   ; y coor will be always < 128 so you can gain 2 cycles by deleting this line
   ADC #100
   sta dest+1   ; program automodification = faster operation
   ldy _x
   lda #255   ; just to test routine , there is actual pixelval
dest
   STA ($00),y
   rts
gentab   ; generates tables with columns' values
   LDA #$00   ; LSB of screen
   LDX #$04   ; MSB of screen
   LDY #0
loop
   STA zeropage,y
   INY
   sta temp
   txa
   STa zeropage,y
   lda temp
   INY
   CLC
   ADC #40      ; 40 rows
   BCC _a
   INX
_a
   CPY #50
   BEQ stop
   jmp loop
stop
   RTS
and slower variation using only 4 zeropage registers (possibly only 2):
   *= $1000
_x= 251   ; x
_y= 252   ; y
dyl = 253   ; destination lo
dyh = 254   ;         hi
   LDA #2
   STA _y
   LDA #2
   sta _x
   LDA #0
   STA dyh
   LDA _y
   ASL ;A
   ROL dyh
   ASL ;a
   ROL dyh
   CLC
   ADC _y
   BCC x1
   INC dyh
x1
   ASL ;A
   ROL dyh
   ASL ;A
   ROL dyh
   ASL ;A
   ROL dyh
   STA dyl
   CLC
   LDA dyh
   ADC #$04
   STA dyh
   LDY _x
   LDA #160
   STA (dyl),y
   JMP *
owns 1xC128, 1x128D cr ,1xc64 (broken unfortunately) ,1xc64c ,2xc64g (one is broken) ,~4xc64e ,1x1541 ,1x1541-II ,1x1541C and some chips for those machines ;-)
www.vulture.c64.org
www.rafalszyja.republika.pl
Users browsing this forum: Google [Bot] and 5 guests
