It is currently Sat Nov 23, 2024 2:51 am
PostPosted: Sun Jan 02, 2022 11:30 pm
Hi,
I'm looking for a way to shorten (by the size, not the cycles) a procedure that is performing multiplication of 8bit value to 16bit result (where the result address is not overlapping the value address). So far I got it down to 21 ($15) bytes. Any ideas how to shorten it more?
   org $80
val .byte 121
result .word 0
   org $2000
start:
   jsr mul4
   jsr mul3
   jsr mul2
   jsr mul1
   jmp *
.proc mul1
   lda val
   // nibble swap - 8 bytes
        ASL
        ADC  #$80
        ROL
        ASL
        ADC  #$80
        ROL
        pha
        and #%00001111
        sta result+1
        pla
        and #%11110000
        sta result
   rts
.endp
.print "* MUL1: ", .len mul1
.proc mul2
   lda val
   pha
   :4 lsr
   sta result+1
   pla
   clc
   :4 asl
   sta result
   rts
.endp
.print "* MUL2: ", .len mul1
.proc mul3
   lda val
   sta result
   ldy #4
loop:
   ; ASL16
   LDA result
   ASL
   STA result
   LDA result+1
   ROL
   STA result+1
   ; dec loop
   dey
   bne loop
   rts
.endp
.print "* MUL3: ", .len mul3
.proc mul4
   lda val
   sta result
        lda #$00
        ldx #$08
        clc
m0      bcc m1
        clc
        adc #16
m1      ror
        ror result
        dex
        bpl m0
        ldx result
        sta result+1
   rts
.endp
.print "* MUL4: ", .len mul4
   run start   ;Define run address
* MUL1: $0015
* MUL2: $0015
* MUL3: $0014
* MUL4: $0019
PostPosted: Sun Jan 02, 2022 11:59 pm
   lda val
   rol a
   rol a
   rol a
   rol a
   tay
   and #15
   sta result
   tya
   rol a
   and #240
   sta result+1
   rts
If everything is in zero page, I think that's 18 bytes. You can of course replace the TAY/TYA with PHA/PLA without changing the size.
PostPosted: Mon Jan 03, 2022 12:05 am
If I understand the problem correctly, my proposed solution is 17 bytes if your variables are in ZP, and 21 bytes if not:
mul:                ; result16 = factor8 * 16
    lda #0
    sta result+1
    ldx #4
    lda value
mul2:
    asl
    rol result+1
    dex
    bne mul2
    sta result
    rts
[Edit: One byte smaller and many cycles slower than John's code]
PostPosted: Mon Jan 03, 2022 12:09 am
The 65C02 has STZ, so if you're not running on old hardware you could take 2 more bytes off that.
PostPosted: Mon Jan 03, 2022 12:12 am
Are you sure the code is correct? With either 4 or 5 ROLs it's giving a wrong result.
PostPosted: Mon Jan 03, 2022 12:16 am
I think John might have accidentally switched his AND #15 and AND #240 instructions.
PostPosted: Mon Jan 03, 2022 12:17 am
The code I tested was right, but that was a hurried re-write after my first go, and I didn't edit the post correctly. Swap the AND #15 and AND #240 and it should work better.
PostPosted: Mon Jan 03, 2022 12:18 am
that's the shortest one, indeed. Great job, thank you!
PostPosted: Mon Jan 03, 2022 12:20 am
Correct, thanks!
PostPosted: Mon Jan 03, 2022 12:43 am
Hold on there, buddy!
    lda value
    sta result
    lda #$10
mul2:
    asl result
    rol
    bcc mul2
    sta result+1
    rts
PostPosted: Mon Jan 03, 2022 5:20 am
It is not just a matter of having the shortest code. You have to also ask yourself what do you want to do with the result. If you want to use the result later, then the zero-page locations are better, but you have to reload them into a register down the road. If you want the result right away, then this one might be better as you can get the result immediately
This one doesn't use any zero-page locations but uses all the registers.
ldx #value
ldy #$10
]lp txa
    asl
    tax
    tya
    rol
    tay
bcc ]lp
    rts
PostPosted: Mon Jan 03, 2022 5:34 am
(he says as he posts the shortest code yet :) )
Excellent point.
PostPosted: Mon Jan 03, 2022 7:51 pm
    lda value
    sta result
    lda #$10
mul2:
    asl result
    rol
    bcc mul2
    sta result+1
    rts
Wow, you are a 6502 wizard! :-)
As the others pointed, in such sizecoding everything depends on what you do next with the code and which regs, flags or memory need to be preserved.
Btw, if you anyone is interested in size optimizations there is an ongoing competition in different categories at https://lovebyte.party/ The last year competition was full of great entries on different CPUs.
Users browsing this forum: Google [Bot] and 19 guests
