It is currently Fri Nov 01, 2024 3:44 am
 Post subject: 6502 Assembler question
PostPosted: Sat Jan 09, 2021 9:52 pm
Hello there,
The joined parts are extract from a compilation listing... I have to rewrite the asm source file from there.
Anybody can explain me the signification of the character <'> which follow the instruction LDXIM in the first attachment ?
This kind of instruction appear several time in the listing also with CMPIM instruction.
In the second attachment how describe the table values in the source file ?
And again have the <'> a special signification in this table ?
Thanks for the attention.
Regards.
Philippe
PostPosted: Sat Jan 09, 2021 9:59 pm
Welcome Philippe!
It looks like the ' character introduces a character constant. So 'A would be $65, 'B would be $66, '7 would be $37, and so on. Where you see a ' with no following character, in this case it's a space - you can see in the left columns that it was value $20.
I'm not sure what you're asking there. In this particular assembler it looks like '=' introduces a single byte constant. Other assemblers might use .DBYTE or EQU or some other syntax. (I just made those up - could be mistaken! There will always be some syntax for a single byte constant.)
PostPosted: Sat Jan 09, 2021 10:04 pm
I fully agree with you explanation for the first question. Thanks.
I expect to use A65 for compiling the source.
The question is more or less how to describe a fixed value at an address in the source file.
PostPosted: Sat Jan 09, 2021 10:11 pm
Do you have a link for A65? There's a chance that there's more than one 6502 assembler with that name!
PostPosted: Sun Jan 10, 2021 7:42 am
Till now I have used this in a dosbox :
http://retro.hansotten.nl/uploads/junio ... re/a65.zip
Thanks for the help.
Philippe
PostPosted: Sun Jan 10, 2021 7:45 am
.BYTE (8bits) or .DBYTE (16 bits) seems to be the answer...
But if <'> give $20 what will give a <.BYTE '1> instruction ? Or may be <.DBYTE '1> ?
On my listing $31 ($20 + $11 ?) will be stored at this address.
PostPosted: Sun Jan 10, 2021 8:03 am
I think the idea was that there was a space after the ' and $20 is the ASCII value of a space; so the ' does not stand alone.
PostPosted: Sun Jan 10, 2021 9:21 am
In the listing I think there is no space after <'>. See here after....
When the <'> follow LDXIM or CMPIM it is unsure....
At least TASM dont like <.BYTE '1>....
PostPosted: Sun Jan 10, 2021 9:46 am
but <.BYTE '1'> produce the expected result in the listing...
It is more clear now !
Probably you are right the others instructions should be <LDXIM ' '> with a space between...
PostPosted: Sun Jan 10, 2021 11:28 am
Sounds like you are getting closer: indeed a more conventional assembly syntax would put the single ASCII character in between two apostrophes: 'X'. But the assembler behind the listing you have evidently requires only the first apostrophe: 'X
PostPosted: Sun Jan 10, 2021 4:16 pm
The early Motorola assemblers used the convention of a prefix designating the type of a value.
Most well known is '$' to indicate a hexadecimal number.
Less well known is an apostrophe to indicate an ASCII character.
Unfortunately, they did not choose to implement the clearer convention of surrounding the character between two apostrophes, but that the character following is the literal value. This decision has unnecessarily made the specification of a space character into a fringe case.
To make matters worse, some assemblers refused to accept
 ldaa #'A'
While the text editors at the time did not automatically delete training spaces on a line, reliance on the presence an "invisible" character is inviting disaster. If that trailing space is deleted, the literal value is a carriage return or line feed character depending on the conventions of the operating system for a text file.
Some people coded defensibly by
 ldaa #$20
I used the following technique in my code:
 ldaa #' space
The comment made the intent clear and protected the space character from accidental deletion.
PostPosted: Sun Jan 10, 2021 5:07 pm
Thanks for the help. By chance TASM accept fe <CMP #' '> so solved now...
After work on the source file come the first compiling tries...
I have a lot of unrecognized instructions... Quick check in A65 and TASM documentation show they are not opcodes of 6502.
They are :
CMPIM
JMI
LDAX
LDAY
LDAIM
SBCIM
ANDIM
ADCIM
LDYIM
LDXIM
STAIY
CPXIM
ORAIM
CPYIM
It seems there are addressing mode variants... This is show by the resulting byte on the compilation listing but then I have to translate in a way TASM understand...
I think <CPYIM $00> should become <CPY #$00> and so on for each instruction with IM at mnemonic end. Right ?
More ubiquitous for me is LDAX, LDAY, STAIY and JMI...
Should <LDAX TABLE> become <LDA TABLE,X> and <STAIY RAMPTR> become <STA (RAMPTR),I> ???
And <JMI JMPVEC> become <JMP (JMPVEC)> ?
Thanks for your help !
Philippe
PostPosted: Sun Jan 10, 2021 5:09 pm
I think your suppositions are correct: LDXIM and similar were quite commonly seen, I think, but are these days outside the mainstream. I think I could quite like them, although they are not what I'm used to.
As your listing gives you the hex values of the opcodes that the assembler produced, you can easily check your thinking.
PostPosted: Sun Jan 10, 2021 6:14 pm
Correct.
Parsing the operand and determining the addressing mode is not trivial.
Instead of trying to distinguish between
cpy #<value>
cpy abs
cpy zpg
unique mnemonics were defined for each form.
The same thing was done in the 8008, 8080, Z80 world as assemblers became more "advanced."
lab on the 8008 became
mov A,B on the 8080
while
lai <value> on the 8008 became
mvi A,<value> on the 8080 to
ld A,<value> on the Z80
