It is currently Sat Nov 16, 2024 12:47 am
 Post subject: Help with code anyone??
PostPosted: Wed Jun 01, 2005 2:19 pm
Hello I am doing a computer course at college and the module for this term is Machine code in which we are using 6502.
I have been given an assignment and am having trouble with the second part of the program which needs me to display the answer of a multiplication sum to the i/o screen.
I have completed Program 1 but I was hoping that someone could help me out here with Program 2 as I have spent a long time trying to work it out and just can’t seem to work out how to do it. Any help will be much appreciated.
I am using Michal Kowlalski’s 6502 simulator v.1.2.5
Here is the code I have written for Program 1 :-
.ORG $0200
LDA #$03
STA NUM1
LDA #$05
STA NUM2
CLC
LDX #$00
CPX NUM1
BEQ End
CPX NUM2
BEQ End
Loop: LDA RES
ADC NUM2
STA RES
INX
CPX NUM1
BNE Loop
End:
BRK
NUM1: .DB $00
NUM2: .DB $00
RES: .DB $00
Here is the Assignment brief :-
Program 1 – A program that multiplies two numbers together, and stores the result in memory. The program only has to support numbers that add up to 255.
Program 2 – Extend Program 1 in order to support the displaying of the results to the ASCII Terminal screen. This program only has to consider supporting results that are up to a value of 9 (i.e. the program need only to display results of a single character).
PostPosted: Thu Jun 02, 2005 8:13 am
As you only have to support numbers upto 9 its rather easy. Convert your number to an ASCII character by adding $30 (ASCII for '0') and then store it in the memory location that the simulator uses for character output.
If you want to support bigger numbers then you need to convert the binary value into a series of decimal values representing 100's, 10's and ones. There are several techniques for this: iteratively subtracting 100's, then 10's until just 1's are left; dividing by ten to get the last digit as the remainder; converting from binary to BCD the printing the nybbles.
Andrew Jacobs
