It is currently Fri Nov 15, 2024 4:28 am
 Post subject: cc65 and Mac OS X
PostPosted: Wed Mar 30, 2005 4:12 pm
I just unpacked my old AIM 65 from 25 years ago and thought it might be an interesitng hobby to write some code. Maybe see if I can still develop a small dedicated control device of some sort using a small 6502 SBC.
I ran across cc65 and I am in the process of learning to install and then use on Mac OS X.
I would appreciate any info or experiences others have had using cc65 with Mac OS X. I believe I have it compiled, now I am going back to apply he patches and then re-compile, then learn how to use it.
After all this I will need to get the code from my Mac to my AIM 65. Any clues on how to do this would be much appreciated.
Later,
Andy
PostPosted: Thu Mar 31, 2005 4:01 am
Hi, Andy. I've been meaning to get cc65 running on my Linux box, to use with my unit-test simulator. I know it's not precisely the same, but I'd be happy to compare notes if you run into any problems.
-TimK
J. Timothy King www.jtse.com
team-oriented object-oriented Agile
C++ Perl Java assembly embedded systems
PostPosted: Thu Mar 31, 2005 3:57 pm
Tim, Thanks for the offer to exchange info
Apparently I can get cc65 to compile successfully, but I can't get it to compile a test program (for example the hello.c, included with the package). I suppose it is most likley because cc65 is not installed in the correct place with dependencies, paths and what-not configured. I looked at the docs that came with it, and they seem to do a better job of describing the compiler than helping someone with limited UNIX experience install and use it.
I looked at the Fink doccumentation to see if I could figure out how they install programs, but I can't find anything to help me, again, limited UNIX experience could be part of the problem.
Any clues?
BTW: I just went to your web-site (nice!) and noticed that you have or are working on a simulator for 6502. Any chance this will run under OS X?
BTW2: This forum is rather slow. Any chance we could take this to private email? If so, let me know here and I will contact you through your web-site, if not, OK as well, any help is much appreciated. When the problems get resolved one of us could post a summary here to help others with similar problems.
Thanks,
Andy
