It is currently Thu Nov 21, 2024 10:56 pm
PostPosted: Sat Jul 30, 2016 11:29 am
I found the source code repositry here, but there was no link to it under the "compilers and languages section". Is anyone here using it?
PostPosted: Sun Jul 31, 2016 3:19 pm
It does seem to be in active development, or at least maintenance - if anyone can say that it's in a working condition I think it would be good to include it in the reference section here.
Edit: note repo is now here:
https://github.com/itszor/gcc-6502
https://github.com/itszor/gcc-6502-bits
Maybe you need this branch
https://github.com/itszor/gcc-6502/tree/m65x-gcc8
or maybe this older one
https://github.com/itszor/gcc-6502/tree/m65x-gcc6-virt
Edit: see also previously
viewtopic.php?f=2&t=2937
PostPosted: Mon Aug 01, 2016 12:01 pm
I found install instructions here, so it looks like its working.
PostPosted: Mon Aug 01, 2016 3:13 pm
I think that's just a mirror... but I do see there's a small 6502 simulator inside the project, which makes it even more interesting!
PostPosted: Mon Aug 01, 2016 4:59 pm
The CRTC demo group use it in their BBC demos, e.g. this one.
PostPosted: Mon Aug 01, 2016 5:16 pm
Ah, thanks, that's the vote of confidence we need! Added the link to Compilers and Languages.
PostPosted: Tue Aug 02, 2016 11:36 am
Wh wh wh .... WHAAAAT ?!?
I tough GCC was not portable to 8-bit systems for technical reasons. I will have to check this out, even if it is in a buggy/alpha stage. On which version of GCC is is based on ? They changed from 4.9 in last year to 6.something this year, and a lot of major changes were made to the project, but I didn't find time to investigate them yet.
PostPosted: Tue Aug 02, 2016 11:45 am
Seems to be 6.0.0 (which is a pleasant surprise - I might have thought it would be ancient)
PostPosted: Tue Aug 02, 2016 3:38 pm
A bit of a struggle, but I've managed to build it!
6502-gcc (GCC) 6.0.0 20150516 (experimental)
That's on ubuntu 14.04, 64bit version for x86.
And helloworld.c
/* Hello World program */
/* from http://groups.engin.umd.umich.edu/CIS/course.des/cis400/c/hworld.html */
#include<stdio.h>
main()
    printf("Hello World\n");
runs as advertised:
$ semi65x/semi65x -l 0x200 /tmp/helloworld
Hello World
(Edit: extra steps needed were as follows
- installing flex and cc65
- putting cc65 on the path and also editing the path in a wrapper script
- changing the build script to note ar65's location
- changing the build script to allow multiple builds without a clean start, as I needed to run multiple makes for some reason
PostPosted: Wed Aug 03, 2016 7:32 pm
Ok, so I'm downloading it right now, but it's HUUGE (1gb). Also I am worried by the complete lack of any instructions or doccumentaiton whatsoever, and I do not recognize the traditional gcc folders. Where are binutils, cpp, etc... ? Or maybe it just changed a lot since gcc 4.8, last time I compiled it myself.
PostPosted: Wed Aug 03, 2016 7:36 pm
Be sure to get the auxiliary project too. I got this one as a git clone, but gave up with git cloning the main project, as it was quicker to get the zip file.
https://github.com/puppeh/gcc-6502-bits
The instructions are in the auxiliary project.
PostPosted: Wed Aug 03, 2016 11:37 pm
What clib is the GCC tool chain linking too?
PostPosted: Thu Aug 04, 2016 5:09 am
I think this one, in the auxiliary project:
https://github.com/puppeh/gcc-6502-bits ... r/libtinyc
PostPosted: Thu Aug 04, 2016 12:49 pm
So, you are required to have CC65 in order to compile it. How does this make any sense at all ?
PostPosted: Thu Aug 04, 2016 3:56 pm
I don't know exactly what cc65 is used for in the build, but I don't think it's too unexpected. It might be that with some juggling the newly built gcc could be used for whatever it is, but I can vaguely imagine there might be some chicken and egg difficulty. It's already a two-stage bootstrap.
