hjalfi wrote:
It would actually be completely possible to target Cowgol at the Acheron or BCPL VMs. (Or SWEET-16.) I'll admit that I've been mostly thinking about real machine code, because real machine code is cool?
The backend architecture is pretty flexible, and copes well with register machines, stack machines, hybrid machines, and machines with no stack at all (I had an earlier version of the compiler which produced code for the Apollo Guidance Computer).
Was BCPL bytecode standardised like Pascal pCode? Is the Beeb version documented?
The only "standard" is what appears on Martin Richards website. Look for bcplman.pdf. I've been in-touch with him recently about it all - one down-side is that the sources to all the Beeb stuff have been lost, so just the modern 32-bit stuff remains. (and some historical non-beeb stuff)
However I understand that Cintcode is more or less the same as it has been for a very long time and it has the concept of bytes, halfwords (16-bit) and words (32-bit). It's a sort of stack register model with just 3 registers and most arithmetic opcodes "push" register A into B (discarding the old B contents). Register C is only used for byte indexing. All branches are relative (signed 8 or 16-bit offset) and it has opcodes for things like the switch statement.
A modern BCPL compiler has the ability to output 3 different target codes - INTCODE which is the old, original code, SIAL which is a code for some imaginary RISC-like system which is designed to be easy to translate into native code and Cintcode. The Beeb version was (AIUI) cut-down to just generate Cintcode for a 16-bit machine, but all three of these are described in the manual. Some of the OPC projects (See
http://anycpu.org/ ) have been running BCPL programs via a SIAL to native convertor (although not self-hosting)
(I decided that as BCPL on the Beeb was 16-bit, then my implementation would be 32-bit on the '816 which has worked well - and I went with Cintcode rather than a SIAL to native translator to reduce the memory footprint. The compiler and cintcode generator is just a 42KB binary and my simple screen editor is about 2K of binary cintcode vs. 16KB of 6502 code for the C version compiled with cc65)
But yes, as you say, native code is cool
It's also often bulky and at the whim of the underlying architecture and targeting the 6502 from a compiler has never been easy.
See my
Ruby 6502 and 65816 SBC projects here:
https://projects.drogon.net/ruby/
