It is currently Wed Sep 18, 2024 11:10 pm
PostPosted: Thu Apr 02, 2020 2:14 am
I was wandering the 'net and somehow kept noticing that more than a few 65xx programmers were taking more effort than necessary to sign-extend integers. I've been playing with 65xx assembly for at least 39 years, and I really can't remember if I got this little ditty from somewhere else long ago and simply forgot from where, or if it's an original idea of mine. Either way, here it is, all ten bytes and 13 cycles worth:
; Sign-extend A to 16-bits in ZP
    sta  ZP
    lda  #$7f
    cmp  ZP   ; cc for <0, cs for >=0
    sbc  #$7f
    sta  ZP+1 ; $ff for <0, $00 for >=0
; Promote int16 in ZP to int32
    lda  #$7f
    cmp  ZP+1 ; cc for <0, cs for >=0
    sbc  #$7f
    sta  ZP+2 ; $ff for <0, $00 for >=0
    sta  ZP+3
[If you're feeling a bit kinky, you can replace the SBC #$7F with ADC #$80 ...]
Comments, critiques, suggestions, corrections, insults?
PostPosted: Thu Apr 02, 2020 8:53 am
With CMOS instructions, I can cut the 8->16 case down to 9 bytes with the same average cycle count (either 11 or 15 cycles, depending on sign):
  STA zp
  STZ zp+1
  ASL A ; carry set for negative
  BCC :+
  DEC zp+1
: ; continue
You could avoid the ASL A if the flags already reflect the contents of A, and branch on BPL instead of BCC. This saves 1 more byte and 2 cycles. This even has the virtue of preserving the value in A.
For the 16->32 case:
  LDA #0
  BIT zp+1 ; N flag reflects value in memory
  BPL :+
  DEC A
: STA zp+2
  STA zp+3
This is 11 bytes, best-case 14 cycles, worst-case 15 cycles. Not quite so good - but if we delete the final STA (thus extending the sign by only one byte), we are back to 9 bytes and 11-12 cycles.
PostPosted: Thu Apr 02, 2020 1:33 pm
The Sign-extend section the Nesdev Wiki's synthetic instructions page offers a similar technique for a constant-time replacement of A with its sign extension, but this one uses no branches. If one bookends it with a STA zp and a STA zp+1, it's almost (but not quite, by 1 byte and 1 cycle) as good as yours. It might be useful if you don't want to store A in the zero page, though, since it doesn't rely on re-using the original value of A as you need to do with your CMP.
      ; Constant-time version, but destroys the carry
            ASL A           ; sign bit into carry; use CPX etc. if using X reg
            LDA #$00
            ADC #$FF        ; C set:   A = $FF + C = $00
                            ; C clear: A = $FF + C = $FF
            EOR #$FF        ; Flip all bits and they all now match C
PostPosted: Thu Apr 02, 2020 6:18 pm
As always, there's more than one way…
PostPosted: Mon May 11, 2020 10:24 pm
Cute tricks, I like them. Will come in handy for me fairly soon.
