It is currently Sat Oct 05, 2024 12:17 pm
 Post subject: Variables in Assembler
PostPosted: Tue Dec 03, 2019 2:28 am
Hello,
I'm new to assembly, so I'm struggling with some of the basic concepts. I'm not new to programming, just assembly.
Anyway, I'm using ACME right now, and I've written a "Hello World" program that displays "Hello World" on a 20x4 LCD display hooked up to the VIA. To start with, I hard coded the string into the assembly program using
  *=$8100
.hello !text "Hello World",0,$FF
That put the ASCII codes for "Hello World" followed by a 0 and $FF at address $8100 in the ROM.
I then had some code that copied that to address $0300 in RAM:
COPY_TEXT:
   LDX #$00
COPY_LOOP:
   LDA $8100,X
   STA $0300,X
   BEQ COPY_DONE
   INX
   JMP COPY_LOOP
COPY_DONE:
   RTS
Finally, I had some code that put the "text" at $0300 out to the VIAs outputs in such a way that it would display it on the LCD.
OUT_TEXT:
   LDX #$00
OUTLOOP:
   LDY $0300,X
   BEQ LOOP_DONE
   JSR DATA
   INX
   JMP OUTLOOP
LOOP_DONE:
   RTS
(the code at DATA would put the data on the VIA's outputs so that the LCD new it was getting data instead of a command).
The thought process was that eventually, I could put any text I wanted at $0300, and then call the OUT_TEXT subroutine, and the text would be displayed.
The problem I'm having is that I can't figure out how to have variable strings.
For example, say I want to put, "Some Variable = $12" on the LCD, I figured I could create a string with something like
.variable=$12
.string !text "Some Variable = ", #.variable,0
Then call some code to copy .string to $0300, then call the OUT_TEXT subroutine, and I'd have my text on my LCD.
But that second line of code hard codes the value into the ROM, and doesn't create anything in the memory that is dynamic.
Is there a way for me to create a dynamic string, or do I have to create a static string for the "Some Variable = " part, and when I need to set it into $0300, copy it out there, then copy the variable's value, then call OUT_TEXT?
I know this is super basic, and I'm sorry for that. I've read through the docs for ACME a few times looking for an answer to this, and haven't found one. I've searched the internet, and haven't found an answer there, either.
Thanks a bunch.
PostPosted: Tue Dec 03, 2019 5:42 am
Welcome!
I think that you have already shown competence on many of the important concepts (at least enough to know how to ask the right questions), and that's a good thing. I feel that your next step (toward the answers you seek) might be to enter the realm of pointers, by designing a putstring subroutine which accepts a 16-bit address argument, say in registers A (high) and Y (low). This would provide you with more flexibility, and would be a great introduction to one of the 6502's signature features, the (zp),Y addressing mode. I am tempted to show you an example, but I'll hold off until you've had a chance to digest this.
PostPosted: Tue Dec 03, 2019 12:40 pm
That's precisely what you need to do. You might define interpolated variables something like this:
varval:     .text   "thingie = "
            .db     $FE             ; marker for interpolation
                                    ; $FE = print 16-bit decimal value
            .dw     $02F0           ; location of value to interpolate
            .text   ".",$13,$10     ; follow with period, CR, LF
            .db     $00             ; marker for end of string
You then need to write a small interpreter that reads through this and, when it encounters the $FE, knows to read the next two bytes as an address, then read the value from that address, convert it to printable form, and put that in the output buffer. (This is basically how C's printf() or Python's str.format() work, if you think about it.)
(Those probably aren't ACME mnemonics, BTW, but the general idea should be clear. .db is "define byte" and .dw "define word," the latter placing the word into memory in little-endian order on a 6502.)
PostPosted: Tue Dec 03, 2019 2:25 pm
Thanks for replying.
cjs wrote:
(Those probably aren't ACME mnemonics, BTW, but the general idea should be clear.)
The general idea, I think is clear, but the actual implementation in ACME isn't, unfortunately. What compiler are you using there?
PostPosted: Tue Dec 03, 2019 2:28 pm
barrym95838 wrote:
Welcome!
Thanks for your kind words. I'm familiar with zp,Y addressing, although I've never used it. I'm not sure how I could take two 8 bit values from the a and y registers and combine them into a 16 bit address, though. I'm assuming that I would use the 16 bit address to point to the location of my string that I want to output. But how would I actually construct the string itself in memory? Do I have to do it byte by byte using ASCII codes, or can I just do something like "This is my string" and then copy that into my memory location?
Rick
PostPosted: Tue Dec 03, 2019 4:21 pm
I'm using the "I just made it up" assembler. :-) But the pseudo-ops are more or less along the lines of what many assemblers for many platforms use. (ACME, for whatever reason, is rather different.) It might assemble like this:
8000                   .org    $8000
8000 74 68 69  varval: .text   "thingie = "
8003 6e 67 69
8006 65 20 3d
8009 20
800A FE                .db     $FE             ; marker for interpolation
800B F0 20             .dw     $02F0           ; location of value to interpolate
800D 2E 13 10          .text   ".",$13,$10     ; follow with period, CR, LF
8010 00                .db     $00             ; marker for end of string
Hopefully looking at the ouput bytes at the left will make it clear exactly what these pseudo-ops deposit in memory. That's all there is to it; it's up to you to write code that reads those data, interprets them, and takes the desired actions based on them.
PostPosted: Tue Dec 03, 2019 5:45 pm
I LOVE that assembler!
8000                   .org    $8000
8003 6e 67 69
8006 65 20 3d
8009 20
I wouldn't say that the code on the left makes it clear. But, I know where to go to see what those codes mean, and then, combined with the assembly you put there, I think it will be clear in a short amount of time.
I appreciate you spending a little extra time to help me out!
Thanks
Rick
PostPosted: Tue Dec 03, 2019 5:56 pm
I was expecting the hex codes at the address to be OP codes, but it looks like you're just storing bytes of information (or words in the case of .dw) in the ROM directly--hard coding the string if you will.
I was hoping for a way to assign a string. Like, I can store the value $AB in address $0345 in RAM by doing
  LDA #$AB
  STA $0345
I'm looking for a way to store a string that is created at run time in a given address the same way. I know I can't store a string in the accumulator, of course. So I'd have to load the string byte by byte into the accumulator and then store it into the address using indexed addressing.
Maybe I'm just too used to higher level languages and this lower level stuff isn't fitting in with what I'm used to.
PostPosted: Tue Dec 03, 2019 7:04 pm
Right. That's exactly what's happening. Just as when, in C, I do this:
static char *message = "Hello, world.";
In both cases the assembler or compiler assigns an address for the data, deposits the bytes at that address, and then binds a name—usable only at compile time—to that address. When code referencing that name is assembled or compiled, the name is replaced by the address.
  LDA #$AB
  STA $0345
Well, that's what happens at runtime. But when the assembler sees those, it simply generates the opcodes and their operands, those get dumped into a file, and when the data from that file get loaded into the memory of the microcomputer and the code is run, the store actually happens. Note that the $AB data is already stored in the machine code: if you look at the listing you'll see that LDA #$AB generated an immediate load opcode followed by that datum: A9 AB. All you're doing is loading that $AB from the location where it was assembled and then storing it in a different location.
So you need to write the assembly code that, when run, will do that.
Yup, that's exactly what you do. Remember, everything you do is eventually just moving bytes around (or modifying them), and a string is just a sequence of bytes. This is true in any language, though higher-level languages usually provide a large library of functions to do this for you.
Perhaps you could tell us what higher-level languages you use, and how you would write this in those, and that will help us provide explanations that draw on your experience with those languages.
PostPosted: Tue Dec 03, 2019 7:24 pm
  LDA #$AB
  STA $0345
[/qoute]
That was a bad example on my part. I'm storing a static value in my example, and I don't want to do that with the string. A better example would be reading in the value of a register on a VIA an storing that into memory. The value you get from the VIA isn't known when the program is compiled/assembled, but you need to act on it somehow. In something like JavaScript you would store it in a variable. In assembly, all I know how to do is store it in a static location in RAM.
OK. Languages I've worked in (note, I'm not professional programmer by any stretch):
  • BASIC (of course)
  • C/C variations (For Arduino and not for Arduino)
  • Java
  • JavaScript
And a few others I haven't played with in years, like
  • Visual Basic
  • Delphi (Pascal)
What I'm trying to do, in a nutshell, is get the value from one of the registers on the VIA, and make a string out of it, and display it on an LCD screen.
So, say that the VIA's PA register is set to input, and when I query it, I get a value of $1F. I want to put something on the LCD like:
"VIA PA=$1F"
But a little more complicated than that. I would actually want:
"ROW 1 COLUMN F"
on the LCD.
I tested this out last night, and I can create a static string in memory for "ROW " and another for "COLUMN ", then use a loop to copy them to memory and insert the values I want shown. Like
.row !text "ROW " ; define static string in ROM
.col !text "COLUMN " ; define static string in ROM
  ldx #$00
COPY
  lda .row,x
  jsr draw_a ; puts that character on the screen
  inx
  bne COPY
and so on. That works, and I understand it. But I'm used to being able to say something like
  var outString="ROW " + value1 + "COLUMN " +value2;
  print outString;
I'm looking for a way to do that first line. Build a string that isn't static, but not have to spell it out character by character using ASCII codes.
Again, thank you for spending your time on this!
PostPosted: Tue Dec 03, 2019 7:35 pm
You're going to have to spell it out character by character with ASCII codes; that's how machine-language programming works. But it's not that hard; you've already figured out how to print out bytes from your strings in memory. You just have to pause in the middle and switch to printing out bytes from other sources. Subroutines, using JSR and RTS, can help with this.
Remember, too, that when you read $1F, to print that in human readable form you're going to need to convert it into two characters. The ASCII character code $1F is a control character, and will print nothing or something unreadable on the terminal; you need to turn that into the two ASCII characters $31 ('1') and $46 ('F') and print each one individually. You may have a bit of work ahead of you to learn how to do that, but there are plenty of examples around of that sort of thing.
PostPosted: Tue Dec 03, 2019 7:39 pm
Well, that's not fun!
Yea. I'm not exactly looking forward to that part, to be honest. I know that for a single digit, you add #$30 to it, but that doesn't work beyond 0-9, so it won't be easy. Maybe, if I'm lucky, Google will be my friend there, and I won't have to rewrite that from scratch.
PostPosted: Tue Dec 03, 2019 7:59 pm
In assembly language, you get control over every teensy detail. That's not to say it has to be unreadable or that the level of the language has to remain super low. After you get your feet wet, you can start venturing into macros, and do things like
       DISPLAY_IMM    "Press CONTINUE when ready"
       WAIT_FOR_KEY   CONT_KEY
or go further and mix variable data in with the constant portions, or even have fields where a cursor can be moved around and the user can edit those portions. You have full control of what your macros assemble; but once they're in place, you don't have to keep looking at the internal details every time, and the line that invokes the macro can be rather English-like. IOW, there's no need to despair over assembly language.
PostPosted: Tue Dec 03, 2019 9:13 pm
Many C compilers can also output the machine code they generate: it might help to compile a few fragments and study the code, if there's a simple CPU you're familiar with and a compiler for it. Matt Godbolt has an online demo of such a thing, with many compilers and many targets, at godbolt.org
PostPosted: Tue Dec 03, 2019 9:23 pm
         ldx #<stgaddr         ;string address LSB
         ldy #>stgaddr         ;string address MSB
         stx zpptr             ;ZP pointer LSB
         sty zpptr+1           ;ZP pointer MSB
         ldy #0                ;starting index
L0000010 lda (zpptr),y         ;get from string
         beq DONE              ;end of string
         jsr putchr            ;write to output
         iny
         bne L0000010          ;do next char
DONE     RTS                   ;exit
The above uses MOS Technology/WDC syntax (the assembly language standard for the 6502 family) and assumes the string is terminated with a null ($00). Maximum string length is 255 bytes and two locations on zero page are required for the string pointer. Also, it is assumed your "character out" subroutine preserves at least the .Y register.
