It is currently Sun Sep 29, 2024 6:23 pm
PostPosted: Fri Nov 15, 2019 8:53 pm
I'm using 64tass to build an application composed of optional modules
to avoid a lengthy list of includes I created a macro
I have a table of all the modules with value 0 or 1 (one if wanted)
MODREGS = 1
MODLOAD = 1
MODEXIT = 0
DEFPKG .MACRO CMD, FILE
.IF MOD\CMD
.INCLUDE "commands/" .. \FILE .. ".asm"
.ENDIF
.ENDM
with this macro I can reduce the include to 1 line by module
ex:
CMDLOAD .DEFPKG LOAD, "load"
CMDREGS .DEFPKG REGS, "regs"
here the content of "load" is only called from a table of pointers (the pointers are correct)
but for regs it's call directly (if the module is assembled in the code) or via the table of pointers
via the table of pointers, it always works
for the direct call the label CMDREGS is defined as 0000 so the application crashes
code generated:
.612b 20 26 62 jsr $6226 JSR PRTCRLF
.612e 20 00 00 jsr $0000 JSR CMDREGS ;- display the registers
.6131 2c 0e 7a bit $7a0e CMDLOOP: BIT STUFFED ;- suffed mode ?
64tass works fine but I'm new with 64tass and I'm really struggling with the macro
any idea on how I could solve this problem?
thanks
PostPosted: Mon Nov 18, 2019 9:51 pm
Hello!
I tried the source code fragments provided with all release versions of past 6 years without success.
Please try to reduce the source code to a minimal but complete example which reproduces this behaviour. The version number and command line options may be interesting as well.
; 64tass Turbo Assembler Macro V1.54.2095 listing file
; 64tass --verbose-list -L listing.txt test.asm
; Mon Nov 18 21:08:15 2019
;Offset ;Hex            ;Monitor        ;Source
;******  Processing input file: a.asm
=1                                      MODREGS = 1
=1                                      MODLOAD = 1
=0                                      MODEXIT = 0
                                        .ENDM
                                        *=$1000
.1000                                   CMDREGS
                                        .IF MODREGS
                                        .INCLUDE "commands/" .. "regs" .. ".asm"
;******  Processing file: commands/regs.asm
.1000   ea              nop             NOP
.1001   60              rts             RTS
;******  Return to file: a.asm
                                        .ENDIF
.1002   ea              nop             NOP
.1003   20 00 10        jsr $1000       JSR CMDREGS
>1006   00 10            .ADDR CMDREGS
;******  End of listing
