It is currently Fri Nov 22, 2024 12:51 pm
 Post subject: jmp (abs,x)
PostPosted: Sat Apr 06, 2019 10:03 am
I recently had another "don't know what you don't know" moments - in that I thought I was generally OK with the 65C02 instruction set, however for some weird reason, jmp (abs,x) escaped me and I only noticed it when brushing up on the '816 instruction set...
I recently posted a command-dispatcher that looked like:
        lda     cmdI                    ; Get command index
        asl     a                       ; Double to index into jump table
        tay
        lda     commandList,y
        sta     wooly+1
        iny
        lda     commandList,y
        sta     wooly+2
        jsr     wooly                   ; JSR to the command and hope for an RTS
        jmp     rubyOsCmd
; The wooly jumper
wooly:  jmp     $FFFF                   ; Modified
The immediate optimisation (not that's it's really needed is to remove the iny and replace the subsequent lsa with lda commandList+1,y, however the jmp (abs,x) mechanism is far more compact, less cycles and less code, so why not, and I've now replaced all that with:
        tax
        jmp     (commandList,x)
Anyway, there you are, in-case it helps anyone else, or jogs their little grey cells...
 Post subject: Re: jmp (abs,x)
PostPosted: Sat Apr 06, 2019 10:08 am
Differences between NMOS 6502 and CMOS 65c02
PostPosted: Tue May 28, 2019 7:56 pm
Ahh thanks for letting us know, I made a similar thing by abusing RTS with the command table pointing to the Addresses - 1 which I patted myself on the back for lol. replacing it with a jmp now :)
            LDA T_COMMAND_TAB,X
            TXA
            ASL A
            TAX
            LDA T_COMMAND_ADDR+1,X
            PHA
            LDA T_COMMAND_ADDR,X
            PHA
            LDX #$01
            RTS
T_COMMAND_ADDR:
 .WORD DISPLAYRAM-1
 .WORD BRKTEST-1
 .WORD JUMP-1
 .WORD SREC-1
 .WORD MEMTEST-1
 .WORD READMEM-1
 .WORD SLEEP-1
 .WORD WRITEMEM-1
 .WORD FILL-1
 .WORD HELP-1
PostPosted: Tue May 28, 2019 9:33 pm
I've also been using that CMOS instruction/address mode for many years now... example from my current monitor code:
CMON            JSR     RDCHAR          ;Wait for keystroke (converts to upper-case)
                LDX     #MONTAB-MONCMD-1 ;Get command list count
CMD_LP          CMP     MONCMD,X        ;Compare to command list
                BNE     CMD_DEC         ;Check for next command and loop
                PHA                     ;Save keystroke
                TXA                     ;Xfer Command index to A reg
                ASL     A               ;Multiply keystroke value by 2 (command offset)
                TAX                     ;Xfer Command offsett address to table MONTAB
                PLA                     ;Restore keystroke (some commands send to terminal)
                JSR     DOCMD           ;Call Monitor command processor as a subroutine
                BRA     WARM_MON        ;Command processed, branch and wait for next command
DOCMD           JMP     (MONTAB,X)      ;Execute CMD from Table
CMD_DEC         DEX                     ;Decrement index count
                BPL     CMD_LP          ;If more to check, loop back
                JSR     BEEP            ;Beep for error, not valid command character
                BRA     CMON            ;Branch back and re-enter Monitor
In the past few years, I've continued rewriting parts of my code to leverage many of the newer instructions and addressing modes. At this point, I don't think I could go back to writing code for the NMOS only CPU :mrgreen:
