It is currently Fri Nov 15, 2024 8:35 am
PostPosted: Mon Dec 27, 2004 7:25 am
I am confused when i use "stz" to clear memory that located in zero page in w65c02s instruction sets.
first I defined
year equ e4h
then .......
stz year
the confusion appeared.after compiled,the instruction opcode is "9c e5 00" rather than "64 e5"that i think reasonable.So when the program runs to this step stop will inevitably happen and notify "Error instruction (opcode)at address ....".But even the exactly same intruction sometimes is compiled normally and other times abnormally.
certainly,if using "lda ...,sta ..."replace it ,compiling process is ok,I don't understand why this happened.
PostPosted: Mon Dec 27, 2004 9:31 am
Which assembler and emulator are you using? We might be able to help if you give us some more information.
Andrew Jacobs
PostPosted: Mon Dec 27, 2004 9:53 am
STZ in zero page is $64, otherwise $9c. I.e. both
64 e5
and
9c e5 00
are fine!
The only difference is that the first version saves one byte and is slightly faster.
PostPosted: Mon Dec 27, 2004 7:54 pm
The original message hints at two different problems.
1. Even though the 'year' constant is in the $00-$FF range the poster indicates that his assembler is generating an absolute rather than zero-page instruction.
This suggests assembler in use is in error or some other factor not visible in the short code sample is misdirecting the assembler.
2. The code appears to be being executed in some kind of emulator that does not support 65C02 opcodes. If this is the case then the poster should stick to the 6502 opcode set and configure his assembler to reject extended instructions.
More information about the assembler and emulator in use might help determine what is going on here.
Andrew Jacobs
PostPosted: Tue Dec 28, 2004 6:49 am
firstly thank you all.
basically,I know the difference of "64.." and "9c..." that generated from "STZ", and then that is my point I don't understand. "STZ YEAR" there should be correspondant to "64.."not "9c.."and so I think it is my assembler's fault.
The assembler i am making use, i think, may be not familiar to you.The IC , manufactured in taiwan, just use 6502 core and then use their own assembler.So I am not very confident to the assembler. [/b]
Users browsing this forum: cjs and 1 guest
