It is currently Sun Nov 24, 2024 1:27 am
PostPosted: Mon Mar 25, 2019 12:45 am
Really simple question. Reading this it seems that branch instructions index off of the next instruction. For instance:
LABEL INA ; lets say our label address is 0000 for simplicity
BRA LABEL ; Here we'll be branching to the previous line, so -1 from the current address, but -3 from the next address.
When assembled, would BRA LABEL be BRA -1 or BRA -3 (80 FF or 80 FD)?
The document I mentioned shows the case of:
LABEL BRA LABEL+2 ; 3 cycles
Now, if this were to assemble to BRA 0 we'd be on top of the next instruction, as it seems to imply, but if it assembles to BRA -2 since the label is 2 addresses behind the next instruction, we'd be infinite looping on our current instruction. Which way is correct?
PostPosted: Mon Mar 25, 2019 1:17 am
When assembled, would BRA LABEL be BRA -1 or BRA -3 (BRA FE or BRA FC)?
It would be BRA -3 or BRA $FD. The 6502 uses two's complement for negative numbers.
BRA 0 is correct (-2+2=0). You could see it as a 3 cycle 2 byte NOP.
PostPosted: Mon Mar 25, 2019 1:22 am
Thank you for the quick response.
I knew about two's complement, I messed up my numbering, I corrected it but it seems you caught it before I got to it :)
This is what I had thought, and why I didn't use the code that I got out of my assembler, as I figured this would be a stumbling block. Many thanks, now I can make this change and get on with some more features that are badly needed.
