It is currently Sat Sep 21, 2024 2:51 am
 Post subject: Problems with CRC-16
PostPosted: Mon Mar 04, 2019 12:26 pm
Hi
I am trying to compute CRC-16 for a SD Card, and I found the table-based version given in the source repository (http://www.6502.org/source/integers/crc.htm) was fast.
Anyway, the results I get are not the same as those reported by the SD Card. Anyone knows if the code is ok? :?
 Post subject: Re: Problems with CRC-16
PostPosted: Mon Mar 04, 2019 1:23 pm
kakemoms wrote:
Hi
Are you sure the SD card is using CRC? My (somewhat new and possibly limited) experience is that they don't use CRCs when used in SPI mode - that's assuming you're using SPI mode. However you do need a few CRCs in the initial setup commands but you don't need to calculate these as they're fixed and well known anyway.
My experience is based on writing an SD card filesystem in the past few weeks which uses SPI to communicate with the SD card and other than two (I think) cases for the setup commands, I don't use CRCs at all.
You may actually want CRCs though, in which case just ignore my witterings :)
PostPosted: Mon Mar 04, 2019 2:53 pm
I used that CRC code with my xmodem routines and it worked properly for me. I read somewhere that some CRC's use different initial values. Not sure if that is true or if that might apply to your case.
PostPosted: Mon Mar 04, 2019 4:30 pm
Not only different IVs, but different polynomials, output XOR filters, and even evaluation directions. CRC can be a real mess, *especially* the 16-bit ones.
Find out exactly which CRC variant is in use here. Until you know that, you won't be able to produce matching values.
PostPosted: Mon Mar 04, 2019 5:07 pm
kakemoms wrote:
Hi
Only the initialisation commands need a CRC byte and those are all fixed sequences. You don't need to send CRCs when reading or writing sectors.
PostPosted: Mon Mar 04, 2019 5:10 pm
kakemoms wrote:
Hi
Well, I have been using it without CRC16 checking until now, but the block data is sometimes corrupted, so I want to check it for that reason.
I am not sure its a valid CRC code, but all 512-byte block transmissions (from the card) end with two extra bytes. If those are not the CRC16 code, I don't know what they are. I have also checked the block data with Active Disk Editor, and it looks ok (and it does not contain the two extra bytes).
I am not talking about command CRC checking. That uses CRC7, not CRC16.
PostPosted: Mon Mar 04, 2019 5:16 pm
All docs indicate CCITT, meaning a 1021 polynomial (normal coding). Maybe I should check the other polynomial variants..
I also found an online coder so I will try to run some test strings with that: https://www.scadacore.com/tools/programming-calculators/online-checksum-calculator/
PostPosted: Mon Mar 04, 2019 5:22 pm
kakemoms wrote:
kakemoms wrote:
Hi
Right. You get those extra 2 bytes even with CRCs turned off. At least I do - at which point I ignore them. I read the 512 bytes, then do 2 more dummy reads. Same for writing, I send the 512 bytes, then 2 0xFF bytes. The disk editor is probably hiding them from you as it's only going to present the 512 data bytes and not the CRCs (I guess - I've just been block dumping my cards from a Linux PC to test my writes and reads, and from Linux I only see the 512 byte data blocks).
I've not noticed any data corruption though - but then I'm not quite ready for stress testing it to any great degree yet.
From what I gathered, CRC is off when using SPI by default (except the initialisation commands), so you need to send the right command to turn it on and then presumably write the correct crc16 bytes for each block written too. I've never turned it on in my code.
PostPosted: Mon Mar 04, 2019 6:33 pm
Yea, "CRC" is not enough to be specific as to WHICH CRC. MD5, for example, is quite specific, but CRC is more a technique than a specific algorithm or values, so knowing the precise CRC equation is important.
PostPosted: Mon Mar 04, 2019 7:37 pm
Ok. I have tested Paul Guertin's code with these databytes:
TESTDATA
        byte $01,$02,$03,$04,$05,$01,$02,$03,$04,$05,$01,$02,$03,$04,$05,$06
Those 16 bytes give me a CRC of $19 $8D.
Running the same 16 bytes through https://www.scadacore.com/tools/programming-calculators/online-checksum-calculator/ gives:
CRC-16-CCITT
(X.25, V.41, HDLC, XMODEM, Bluetooth, SD, many others; known as CRC-CCITT)
Normal 0x1021 86 0C
Strangely enough, this CRC generator: https://www.lammertbies.nl/comm/info/crc-calculation.html gives:
CRC-CCITT (0xFFFF) 0x8D19
Very strange.
PostPosted: Mon Mar 04, 2019 8:09 pm
Ok. It suggests I have to turn CRC on.
I only have reading working at the moment, so it is basically to check for errors without having to re-read each block which would take more time. Actually for a slow 6502 it may take less time if you run the SPI at 25MHz, but I plan to run the 6502 at around 28MHz.
PostPosted: Mon Mar 04, 2019 8:33 pm
I have the luxury of coding all mine in C on an ATmega that's the host to my 6502 system. Currently running the SPI clock at 8Mhz and using one of the sparkfun level shifter boards - 8Mhz is the max. possible on a 16Mhz ATmega. (after running it at 400Khz during initialisation) I've no plans to turn data CRCs on if I can possibly avoid it...
What sort of filing system are you looking at? I'm writing one loosely based on ProDOS8... So max. 32MB 'disk' but it reads a standard MBR, so 4 disks of 32MB each is possible - for now.
(currently have an 8GB microSD plugged in - all that space ... ah well!)
PostPosted: Mon Mar 04, 2019 9:13 pm
I bought a load of second hand 128MB and 256MB microSD cards a few years ago for retro computing projects - Largely pulls from old Nokia and Blackberry phones it seems. I also have some (possibly too many) 256MB compact flash cards and IDE adapters.
When I tried to buy cheap low capacity USB thumb drives last summer the smallest I could get was 2GB (White porcelain with a blue Chinese print - quite fetching). A quick search just now shows 4GB is becoming the new low limit.
PostPosted: Mon Mar 04, 2019 9:28 pm
I know :-( It's a bit ridiculous, but I really didn't want to go to floppys or my little retro project, much as I love my 40 year old Apple II ones that still work.. So I'm sort of pretending an SD card is a floppy - after all, it's about the same flexibility as a 3.5" disk is... ;-)
PostPosted: Mon Mar 04, 2019 10:39 pm
I know what you're talking about. All that "wasted space".
For a Forth standpoint, a 16 bit Forth that is, 65MB is the peak, since you can only have 65,000 "screens" (which are 1K each).
When I think about 65,000 screens - man, that's a lot. On the other, it's a lot of wasted space (screens are simple, not efficient :) ).
But the key point, to me, when thinking about this stuff, and off putting to me, was that, yea, using an SD Card as a floppy (or, pretty much anything), is all well and good, but what you (I) really want is the ability to copy data off of the system. For that, you need TWO "floppies".
Yea, I know, lots of work was done with one floppy back in the day, I, too, had a single floppy drive in the dark ages.
But, it sure is nice to NOT have to "swap floppies", especially something as fiddly as a SD Card. (Edit -- can you imagine trying to copy a 8MB section with a 32K RAM buffer? 256 swaps later..."Is that a callous on my thumb? Why is my flash connector loose?")
So, that's where I always stalled out. "Just put in an IDE SD Card". Sure ok, but, then..hey -- how do I make copies. "What a pain!"
Which is why I'm where I am today fixated on USB. One USB connector and a Hub, and "suddenly", I have 4 "floppies" (or whatever, more than one certainly). From here everything collapsed in to the singularity of using the RPI as an I/O controller. Maybe I'll call the project Singularity instead of SuperPI/O.
(Which brings up "If you have network ability, who needs a second drive?". Gah...)
