It is currently Fri Sep 20, 2024 12:27 pm
 Post subject: Simple dot
PostPosted: Fri Feb 01, 2019 5:20 pm
Hello. I'm trying to figure out how it is possible to display a single pixel anywhere on the screen. Do you write a value to a specific address? If you could do that in Easy6502, why can't you do it when writing code for an nes game?
 Post subject: Re: Simple dot
PostPosted: Fri Feb 01, 2019 5:41 pm
In brief, there are many different ways of doing video. Mostly, RAM was rather expensive compared to the desired resolution, so you have more than one pixel controlled by a byte. But also, RAM is rather slow compared to video, so if one byte controlled one pixel, you'd need a great number of RAM accesses to fetch the video data.
So, it's more normal to see video modes where one byte controls 2, 4 or even 8 pixels. Or, in the case of a character-mode display, in a sense one byte controls 64 pixels.
Easy6502 is a simple model, and is written as software, so it can present a more user-friendly interface.
PostPosted: Fri Feb 01, 2019 6:16 pm
Also, keep in mind the NES only has 2K of RAM by default. Some carts added more RAM but as a general rule, you're working with a 2K system. In order to have single pixel access (especially in multiple colors), 2K of RAM would only support very small resolutions. Which is why the NES (and many 8-bit computers) worked in tiles (chars) and even meta-tiles (collections of tiles).
PostPosted: Thu Feb 07, 2019 9:14 pm
Also, the 1.79MHz 6502 speed is way too slow to draw NES style games on a framebuffer. If you were drawing a pixel at a time, you'd be getting seconds per frame instead of frames per second, which is not conducive to arcadey gameplay.
Consider the PPU to be a hardware decompressor from a compressed dictionary of tile/sprite/palette definitions into a streaming full-color video signal. This dictionary is the language that those sorts of games speak naturally, setting a byte (for instance) to change the position of a sprite, instead of all the effort of redrawing it in software pixel by pixel. Anything you wish to display needs to speak that language.
The easiest way to have a single byte show something on such a display is to change a tile, not to change a pixel.
If you want literally 1 pixel to show anywhere on the screen, define a sprite with 1 visible pixel, and position it by setting its X and Y coordinates.
Users browsing this forum: No registered users and 31 guests
