It is currently Fri Sep 20, 2024 2:35 pm
PostPosted: Thu Jan 31, 2019 2:42 pm
Hi All,
I have this bit of code in my CNC-64 main loop
        lda frM                 ; (4) get fraction MSB to test for negitive
        bmi @skipB              ; (3) skip if fraction < 0, else do ystep
         ; Toggle YStep
        lda outByte             ; (4) outByte^=0x04, toggle yStep for each step
        eor bStepBit            ; (4) XOR in ysstep bit (toggle it)
        sta outByte             ; (4) save it
        LIBMATH_SUB16_AAAAAA frL, frM, daL, daM, frL, frM
@skipB  LIBMATH_ADD16_AAAAAA frL, frM, dbL, dbM, frL, frM
        ; Toggle XStep
xsteps  lda outByte             ; (4) outByte ^= 01, toggle xStep for each step
        eor aStepBit            ; (4) XOR in xstep bit (toggle it)
wdone   OutBufWrite             ; (24) implic. 'wdone beq' if buff full in macro
It is a simplified version of the Bresenham algorithm that decides if both the X and Y axis need to step or just X. In cases where delta X > delta Y, then aStepBit is X and bStepBit is Y, or vice versa if delta Y is greater. This works fine. I came up with the idea below which uses more memory but saves about 5 cycles in the cases where both axis are stepping. The problem is that it does not work properly.
        ; Toggle YStep
        eor aStepBit            ; (4) XOR in ysstep bit (toggle it)
        eor bStepBit            ; (4) XOR in xstep bit (toggle it)
        jmp wdone               ; (3)
The difference in the output between the two (one line of buffer) is below. I have stared at this so long that I can't see what is going wrong. Any help appreciated.
Correct:
>C:c000 01 04 05 04 05 00 01 00 01 04 05 04
Incorrect:
>C:c000 01 fe 05 04 05 fe 01 00 01 fe 05 04
PostPosted: Thu Jan 31, 2019 3:01 pm
Can you post a bit more code e.g. Wdone. Is important what the flags are?
Also can you put the Toggle YStep code after the sub add? Then you can combine the last eor and store.?
Not sure it saves 5cycles as you have to add the Jmp.
PostPosted: Thu Jan 31, 2019 3:14 pm
I added 'wdone' to the listings above, it comes after the other code so has no effect.
The 'outBufWrite' expects the value to be in A so if I rearrange things I will still need to stash A somehwere before doing the LIBMATH_ADD_16.
PostPosted: Thu Jan 31, 2019 3:35 pm
outBufWrite : What does it expect to be in A? If the code takes the wdone path A will not be outbyte.
PostPosted: Thu Jan 31, 2019 3:40 pm
A is the byte to be saved to the buffer. If a step is to be made that bit is toggled in outbyte. So, yes I see what you are saying, that I did the ADD?SUB after that so my 'A' got thrahsed! THANKS! I think I was so focused on what I 'thought' it shoudl do I missed what it was actually doing :)
I changed it to below and it now works.
        ; Toggle YStep
        jmp wdone               ; (3)
PostPosted: Thu Jan 31, 2019 3:49 pm
sometimes it just takes someone else to talk too.
You can save a few bytes by removing the ending common subexpression :
        ; Toggle YStep
        jmp wdone               ; (3)
wdone
