It is currently Wed May 15, 2024 3:33 pm
 Post subject: 32bit to PETscii
PostPosted: Sun Sep 09, 2018 1:54 pm
Well, this is nothing new and its certainly only one of many converters, but I made one that is hopefully small (but not so fast):
; Convert 32-bit number to petscii/ascii
; "printsize" is a pointer to the 32-bit number (e.g. 4 bytes)
; Uses two ZP locations for temporary storage ($2 & $3)
; "printtxt" is the null-terminated output string
long2petscii
                ldy #3
pfsl2
                ldx #3
                lda #0
                sta $2
                sec
                php
pfsl3
                plp
pfsl3b
                lda printsize,x
                sta printsize+4,x
                sbc subtable,y
                sta printsize,x         ; store remaining value
                php
                dey
                dex
                bpl pfsl3
                inc $2
                iny
                iny
                iny
                iny                     ; reset y
                ldx #3
                plp                     ; get carry
                bcs pfsl3b              ; still positive
                lda printsize+4         ; now negative, so recall last value
                sta printsize
                lda printsize+5
                sta printsize+1
                lda printsize+6
                sta printsize+2
                lda printsize+7
                sta printsize+3
                iny                     ; next stage
                iny
                iny
                iny
                sty $3                 ;save
                tya
                lsr ;/2
                lsr ;/4
                tay
                dey
                lda $2
                clc
                adc #$2F                ;($2)+$30-1 get petscii code
                sta printtxt,y          ;put number into text string
                ldy $3
                cpy #$2B
                bne pfsl2
                lda #0
                sta printtxt+10
                lda #<printtxt
                ldy #>printtxt
                ;A and Y points to a null terminated string which is the number in Ascii.
                rts
subtable
                byte $3b,$9a,$ca,$00    ;1000000000 (=1G)
                byte $05,$f5,$e1,$00    ;100000000
                byte $00,$98,$96,$80    ;10000000
                byte $00,$0f,$42,$40    ;1000000
                byte $00,$01,$86,$a0    ;100000
                byte $00,$00,$27,$10    ;10000
                byte $00,$00,$03,$e8    ;1000
                byte $00,$00,$00,$64    ;100
                byte $00,$00,$00,$0a    ;10
                byte $00,$00,$00,$01    ;1
printsize
                bytes 8,0
printtxt
                bytes 11,0
If you want something fast, this is not it. But I hope it takes less space than some of the other converters out there (which was the reason I made it). I haven't optimized it (yet), so you can probably shave off some bytes here and there to get it even more compact.
Edit: Ok, some testing shows that it uses 2600 cpu cycles for the number "1" and about 14600 cycles for the number "3999999999" (absolutely worst case). Still only 14ms at 1MHz or 1ms at 14Mhz.. Total code size is 123 bytes.
Users browsing this forum: Google [Bot] and 8 guests
