I'm diving in, once again, to an old project: disassembling and documenting the "KVOS" I found in the ROMs of a KIM-1 I bought several years ago. More information:
https://retroconnector.com/bdc-6500-computer-kim-1/I've learned a great deal since I last left it, and now I've been able to decipher enough of the boot process to work out what I think is the routine for loading a program from tape (maybe paper tape?)
This code looks like it waits for a header like "XXXX"+efabcd
The initial loop waits for an ASCII "X" 0x58, then the first three characters after X are ignored.
the e f bytes are stored in $04, $05
a,b,c,d bytes are stored in $00, $01, $02, $03
Byte c ($02) is subtracted from 0, and stored back in $02
Byte d ($03) is subtracted from 0, and stored back in $03
It then loops with a series of bytes loaded from the 6522, stored at address set in $00,$01. Loops until cd bytes are read.
When it's done loading, jumps to address in $04,$05
In short: "load the program with entry point EF, starting at AB, length CD"
FC1A cld ; D8
FC1B sei ; 78
FC1C ldx #$FF ; A2 FF
FC1E txs ; 9A
FC1F lda #$00 ; A9 00
FC21 sta 6522-DDRA ; 8D 83 15
FC24 lda 6522-PCR ; AD 8C 15
FC27 and #$F0 ; 29 F0
FC29 ora $0E ; 05 0E
FC2B sta 6522-PCR ; 8D 8C 15
FC2E LFC2E: jsr WAITFORIO ; 20 7F FC
FC31 cmp #$58 ; C9 58
FC33 bne LFC2E ; D0 F9
FC35 jsr WAITFORIO ; 20 7F FC
FC38 jsr WAITFORIO ; 20 7F FC
FC3B LFC3B: jsr WAITFORIO ; 20 7F FC
FC3E jsr WAITFORIO ; 20 7F FC
FC41 sta L0004 ; 85 04
FC43 jsr WAITFORIO ; 20 7F FC
FC46 sta $05 ; 85 05
FC48 jsr WAITFORIO ; 20 7F FC
FC4B sta $00 ; 85 00
FC4D jsr WAITFORIO ; 20 7F FC
FC50 sta $01 ; 85 01
FC52 jsr WAITFORIO ; 20 7F FC
FC55 sta $02 ; 85 02
FC57 jsr WAITFORIO ; 20 7F FC
FC5A sta $03 ; 85 03
FC5C ldx #$00 ; A2 00
FC5E txa ; 8A
FC5F LFC5F: sec ; 38
FC60 sbc $02 ; E5 02
FC62 sta $02 ; 85 02
FC64 txa ; 8A
FC65 sbc $03 ; E5 03
FC67 sta $03 ; 85 03
FC69 LFC69: jsr WAITFORIO ; 20 7F FC
FC6C sta ($00,x) ; 81 00
FC6E inc $00 ; E6 00
FC70 bne LFC74 ; D0 02
FC72 inc $01 ; E6 01
FC74 LFC74: inc $02 ; E6 02
FC76 bne LFC69 ; D0 F1
FC78 inc $03 ; E6 03
FC7A bne LFC69 ; D0 ED
FC7C jmp (L0004) ; 6C 04 00
; LOOPS UNTIL INPUT ON 6522. INTERRUPT FLAG BIT 1 SET ON IO AT 6522 PORTA
WAITFORIO:
FC7F lda 6522-IFR ; AD 8D 15
FC82 and #$02 ; 29 02
FC84 beq WAITFORIO ; F0 F9
FC86 lda 6522-INPUTA ; AD 81 15
FC89 pha ; 48
FC8A lda 6522-PCR ; AD 8C 15
FC8D and #$F0 ; 29 F0
FC8F ora #$0C ; 09 0C
FC91 sta 6522-PCR ; 8D 8C 15
FC94 ora #$0E ; 09 0E
FC96 sta 6522-PCR ; 8D 8C 15
FC99 pla ; 68
FC9A rts ; 60
Does this format sound familiar to anyone - 10-bytes of header starting with X, and finishing with three 2-byte words defining where and how much to load? Would programs have been stored on paper tape? Or sent via a serial terminal? Any pointers that might help illuminate the process would be greatly appreciated.
