It is currently Wed Jul 03, 2024 9:22 am
PostPosted: Fri Oct 19, 2018 1:30 pm
So, my 6502 is a little rusty. Been a while since I was active.
I have a delay routine where I want to preserve A, X and Y. Using 65C02, here is what I have:
;       Name:           DELAY1
;       Desc:           Slight delay (TODO, calculate and re-name)
;       Destroys:       Nothing
DELAY1:
        PHA                     ; Push A to stack
        TXS                     ; Push X to stack
        TYA                     ; Transfer Y to A (why no PUSH Y to stack??)
        PHA                     ; Push A to stack (previous value of Y)
        LDX     #$00
        LDY     #$10
_DELAY1:
        DEX
        BNE     _DELAY1
        DEY
        BNE     _DELAY1
        PLA
        TAY                     ; Restore Y
        TSX                     ; Restore X
        PLA                     ; Restore A
        RTS
I'm not at my 6502 computer at the moment...but does this seem to be correct?
Any shorter way to do this?
PostPosted: Fri Oct 19, 2018 1:41 pm
Oops: TXS is not pushing X to stack! It is copying X to the stack pointer, which is to say resetting the stack. On 6502 you need PHA, TXA, PHA, TYA, PHA or similar. On 65C02 I think you can use PHA, PHX, PHY.
PostPosted: Fri Oct 19, 2018 1:44 pm
Ah thanks!
I totally read that wrong. I thought the 65C02 had better stack support but I guess my searching skills are failing me.
Thanks again.
Now my routine is:
;       Name:           DELAY1
;       Destroys:       Nothing
DELAY1:
        PHX                     ; Push X to stack
        PHY                     ; Push Y to stack
        LDX     #$00
        LDY     #$10
_DELAY1:
        DEX
        BNE     _DELAY1
        DEY
        BNE     _DELAY1
        PLY                     ; Restore Y
        PLX                     ; Restore X
        PLA                     ; Restore A
        RTS
PostPosted: Fri Oct 19, 2018 1:58 pm
That would work, but since you don't clobber the accumulator you can delete the PHA/PLA instructions.
What you do clobber is the status register. You can save and restore that with PHP/PLP, if it happens to matter. I advise saving it first and restoring it last.
PostPosted: Fri Oct 19, 2018 2:02 pm
Ah, that's true. I was still thinking that I needed A to hold Y so that's why I was pushing it to the stack.
;       Name:           DELAY1
;       Destroys:       Nothing
DELAY1:
        PHP                     ; Push status register
        LDX     #$00
        LDY     #$10
_DELAY1:
        DEX
        BNE     _DELAY1
        DEY
        BNE     _DELAY1
        PLY                     ; Restore Y
        PLX                     ; Restore X
        PLP                     ; Restore status register
        RTS
PostPosted: Fri Oct 19, 2018 3:19 pm
Here's one, from the impressive mind of dclxvi:
; Delay 9*(256*_a+_y)+26 cycles (+12 for jsr/rts)
; Assumes that the BCS does not cross a page boundary
; Credit to dclxvi for the inner mechanics
delay:
      pha
      phy
      lda   #_a
      ldy   #_y
dloop:
      cpy   #1
      dey
      sbc   #0
      bcs   dloop
      ply
      pla
      rts
You can fine-tune your delay anywhere from 26 to 589841 cycles, with a granularity of 9.
PostPosted: Fri Oct 19, 2018 3:24 pm
Oh wow. That's really clever!
