TNMOC Contest
BitWise
In Memoriam
TNMOC Contest
Post by BitWise »
The honour of the 6502 must be upheld. Read on.
; In the recent 'Grand Digital Computer Race' at The National Museum of Computers
; the two 6502 based machines, a BBC and Apple II only managed 70 and 38 values
; in 15 seconds -- I assume this is because it was coded in BASIC (Yuck!).
; We can do better. We must do better.
; This program works out values with up to 512 digits. On my laptop running in an
; emulator it generates 2542 results in in 0.382394 Secs with an overall CPU
; Frequency = 79.5137 Mhz. Scaled to the BBC's 2Mhz 6502 that would take 15.20
; Secs (approximately). A real BBC would be a bit slower as it has interrupts to
; handle and the I/O  would take longer but even so a more respectable ~2000
; values in 15 Secs should be possible. The Apple II will be around 50% of that
; as its clocked at 1MHz.
; All the real code is 6502 but I've used the WDM opcode in the emulator to
; produce output text (see UartTx) so I compile it as 65816 to enable it.
; Andrew Jacobs
; 2018-02-21
                .65816
; Macros
COMPUTE         .macro  NA,NB,NC,LA,LB,LC
                ldx     #0
                clc
                repeat
                 txa                    ; Reached end of shorter number?
                 eor    LA
                 if ne
                  lda   NA,x            ; No.
                 endif
                 adc    NB,x            ; Add digits (or zero + digit)
                 sta    NC,x
                 inx
                 txa                    ; Reached end of longer number?
                 eor    LB
                until eq
                if cs                   ; Has result extended the value?
                 lda    #1              ; Yes, add a 1 to the start
                 sta    NC,x
                 inx
                endif
                stx     LC              ; Save the new number length
                .endm
DISPLAY         .macro  NM,LN
                repeat
                 lda    NM-1,x          ; Fetch two digits
                 pha
                 lsr    a               ; Extract MS digits
                 lsr    a
                 lsr    a
                 lsr    a
                 if eq                  ; Leading zero?
                  cpx   LN
                  beq   Skip\?  ; Yes, suppress it
                 endif
                 ora    #'0'
                 jsr    UartTx
Skip\?:          pla                    ; Extract LS digit
                 and    #$0f
                 ora    #'0'
                 jsr    UartTx          ; And print
                 dex
                until eq
                lda     #10             ; Send CR/LF to output
                jsr     UartTx`
                .endm
; Workspace
                .page0
                .org    $10
LEN_A           .space  1
LEN_B           .space  1
LEN_C           .space  1
; Number workspaces (for 512 digits)
                .bss
                .org    $1000
NUM_A           .space  256
NUM_B           .space  256
NUM_C           .space  256
; The emulator expects the S28 to contain a ROM image so this is kicked off via
; the dummy reset vector.
                .code
                .org    $f000
Fibonacci:
                ldx     #1              ; Initialise number lengths
                stx     LEN_A
                stx     LEN_B
                stx     LEN_C
                lda     #0
                sta     NUM_A           ; Start with A = 0
                stx     NUM_B           ; .. and B = 1
                sed                     ; Work in decimal mode
ComputeLoop:
                ; C = A + B
                COMPUTE NUM_A,NUM_B,NUM_C,LEN_A,LEN_B,LEN_C
                cpx     #0
                if eq
                 jmp    AllDone         ; Result is over 512 digits
                endif
                DISPLAY NUM_C,LEN_C
                ; A = B + C
                COMPUTE NUM_B,NUM_C,NUM_A,LEN_B,LEN_C,LEN_A
                cpx     #0
                if eq
                endif
                DISPLAY NUM_A,LEN_A
                ; B = C + A
                COMPUTE NUM_C,NUM_A,NUM_B,LEN_C,LEN_A,LEN_B
                cpx     #0
                if eq
                endif
                DISPLAY NUM_B,LEN_B
                jmp     ComputeLoop
UartTx:
                wdm     #$01            ; Use emulator I/O
                rts
AllDone:
                wdm     #$ff            ; Stop the emulator
                jmp     AllDone
                .org    $fffc
                .word   Fibonacci       ; Dummy RESET vector
                .end
Feel free to squeeze a few more cycles out.
fibonacci.zip
Code, Assembler, Emulator and Batch files.
(935.18 KiB) Downloaded 140 times
Re: TNMOC Contest
Nice idea!
Just checking - does the 15 second time limit put a tight constraint on the UART speed, or does that work out to be fine at 19200?
commodorejohn
Re: TNMOC Contest
Post by commodorejohn »
Okay, I'm intrigued. Any more information on the rules? Is 512 (decimal?) digits the specified precision?
Re: TNMOC Contest
The idea, AIUI, is to output as many numbers from the fibonacci sequence as you can, in 15 seconds, using appropriate techniques for the platform. As the numbers get quite long, memory becomes one issue, and i/o bandwidth could be another. I imagine any Basic efforts would be using arrays of integers to model very large numbers. (Edit: or maybe peeks and pokes)
commodorejohn
Re: TNMOC Contest
Hmm, okay, here's my stab at it, though I really haven't proofed it for performance, just wrote a minimal bignum Fibonacci generator:
Edit: nevermind, I messed up on that. Gonna have to go back and re-think my approach a bit.
BitWise
In Memoriam
Re: TNMOC Contest
Post by BitWise »
Nice idea!
They never really made the rules that precise. I think some of the machines are definitely more capable than the results suggest.
On the BBC I'd use mode 7 (teletext mode) to get the fastest screen output and scrolling. Even with a 6551 you could try the 115k (16x) mode.
commodorejohn
Re: TNMOC Contest
Okay, finally got the issues sorted out. The following is code for Kowalski's 6502 assembler/simulator:
	.ORG $1000
	; Macros
printbcd	.macro	; Print a byte in A as a pair of BCD digits
	pha		; Save the value for later
	lsr		; Isolate the high nybble and print it first
	lsr
	lsr
	lsr
	ora #$30	; Turn the isolated digit into its ASCII character
	printchar	; Print the character
	pla		; Retrieve the original value
	and #$0f	; Isolate the low nybble
	ora #$30	; Make it ASCII
	printchar	; Print it
	.endm
printchar	.macro	; Print the character in A as an ASCII value
	; do whatever here
	sta $e001
	.ENDM
	; Fibonacci algorithm - calculates numbers up to 510 digits in BCD form
	; a = 1
	; b = 1
	; print a
	; a = a + b
	; print b
	; b = b + a
init	; Initialize buffers to 0000[...]1
	ldx #$01
	stx bufa
	stx bufb
	lda #$00
.l	sta bufa,x
	sta bufb,x
	inx
	bne .l
	ldy #$01	; Initialize the maximum-length counter
loop	txa		; Check - is X zero?
	beq pashort	; If so, cut the print loop short
printa	; Print buffer A as BCD values, one byte (2 digits) at a time
	lda bufa,x	; X should be left pointing to the current MSB
	printbcd	; Print it as a BCD pair
	dex		; Drop down to the next most significant byte
	bne printa
pashort	lda bufa,x	; Get and print the LSB since the loop ends early
	printbcd
	LDA #$20	; Print a space
	printchar
	; Note: SED and CLD could be moved out of the loop if decimal mode
	; won't affect any other code (i.e. character printing,) but it's a
	; negligible difference anyway.
	sed		; Prep for BCD addition
	clc
	LDX #$ff	; Set X to $FF
addb2a	; Add buffer B to A as BCD values
	inx
	lda bufa,x	; Get the current byte from A
	adc bufb,x	; Add the current byte from B
	STA bufa,x	; Store it back to A
	DEY		; Decrement the maximum-length counter
	bne addb2a	; If it's > 0, go to the next byte
	iny		; If it's 0, reset it for the next iteration just in case
	BCS addb2a	; If we carried out, go to the next byte
	cld		; Leave decimal mode
	TXA		; Update the maximum-length counter
	TAY
	INY
	cpx #$ff	; Did we run to the end of the buffer?
	beq done	; If so, we're done here
	TXA		; Check - is X zero?
	beq pbshort	; If so, cut the print loop short
printb	; Print buffer B as BCD values, one byte (2 digits) at a time
	lda bufb,x	; X should be left pointing to the current MSB
	bne printb
pbshort	lda bufb,x	; Get and print the LSB since the loop ends early
	printbcd
	clc
	ldx #$ff	; Set X to $FF
adda2b	; Add buffer A to B as BCD values
	inx
	lda bufb,x	; Get the current byte from A
	adc bufa,x	; Add the current byte from B
	STA bufb,x	; Store it back to A
	BNE adda2b	; If it's > 0, go to the next byte
	BCS adda2b	; If we carried out, go to the next byte
	TAY
	INY
	printchar
	JMP loop	; If we're not done, continue
done	; If we are done, finish
	brk
	; Buffers
bufa	.set $2000
bufb	.set $2100
It's not super-pretty and I haven't double-checked the exit conditions to ensure that it will quit properly with no erroneous output when the bignum size runs up to a full page. It also uses the simulator's output facility for cheap printing, but I did at least implement my own BCD-to-ASCII conversion in an attempt to be fair about it. Anyway, assuming a 1MHz test system, when run up to just shy of 15,000,000 cycles it produces the following number:
2383972451046333
4341778432843725
1805687861613243
9625858202478278
9140698057971348
5513550524628221
6604878690798813
8893035851040403
0806030527298628
6853890899496037
8909866230416986
5421475796599705
5876430614925437
1892863787317305
7897731694551328
7392301441138267
0293400725105488
1903535683969679
7453359616023179
7925656175919745
2805998203167417
9044885601740086
7886789122530726
0989620372623122
3715318210405157
8714172040612830
4969924233370562
76562264
Which, according to this calculator, is the correct value for Fib(2178) - so yes, a bit over 2,000 Fibonacci numbers.
Re: TNMOC Contest
What would the total number of characters printed be? 250,000? That could become limiting.
commodorejohn
Re: TNMOC Contest
Indeed - if you were using a serial terminal, you wouldn't get but a fraction of that through in 15 seconds. I'd say the best approach to minimize output time would be to write directly to screen memory and forgo scrolling altogether.
Re: TNMOC Contest
(Turns out to be about 500,000 characters for the first 2178 Fibonacci numbers)
(Also might be worth noting that the Beeb's Mode 7 screen should be very cheap to scroll, as the CRTC is used to remap the screen - no block move, just a 40 character clear)
commodorejohn
Re: TNMOC Contest
Yeah, hardware-assist on scrolling would definitely help, but unless there's a requirement otherwise, I'd just dump characters directly to screen memory over top of the previous number and skip scrolling altogether.
Re: TNMOC Contest
That would certainly be quick and easy - but not very convenient for the human wanting to read those numbers!
CurtisP
Re: TNMOC Contest
Post by CurtisP »
I should probably write this in C02 and see what kind of results I get.
commodorejohn
Re: TNMOC Contest
Oh, certainly. But the nice thing about this particular challenge is, as long as you can see it running and you can verify the last number when it stops, you know the previous numbers were generated correctly, and if the only requirement is to display them, then that should be all that's needed.
Re: TNMOC Contest
(BTW here's a short video on the contest. No additional clarity on the rules, as fact as I can tell.)
