It is currently Sat Nov 23, 2024 2:05 am
 Post subject: FastIO Macros
PostPosted: Tue Feb 06, 2018 10:08 am
I had a design which was going to incorporate a FastIO port, specifically the 4-bit option (Thanks Garth & Jeff) which I wrote some macros for the WDC assembler to support it. I have now decided to scrap it from my design, but I wanted to record the macros somewhere for posterity as they might be useful to others. You could quite easily adapt these macros to work with the 8-bit version, too.
; @region FastIoMacros
; Macros for manipulating the FastIO port
; EXAMPLE - How to use RFIO and V2F
;   RFIO    2               ; Read bit 2 from FIO into V
;   V2C                     ; Copy V flag to C flag
;   ROR     A               ; Shift C into the MSb of A
; or
;   ROL     A               ; Shift C into the LSb of A
; EXAMPLE - How to use WFIO
;   ROR     A               ; Shift the LSb out of A into C
;   WFIO    1               ; Write C to bit 1 of the FIO
; or
;   WFIO    2, TRUE         ; Write a '1' to bit 2 of the FIO
; Read FastIO
; Read the given mBit from the FastIO port into the V flag.
RFIO        MACRO   mBit
    IF mBit>3               ; Check that mBit is valid
    EXIT    RFIO first parameter invalid
    ENDIF
    CLV                     ; V has to be cleared as the ~SO pin can only set V.
    ; Special opcode decoded by external hardware. Causes the FIO to use ~SO pin
    ; to set the V flag if the relevant FIO input bit is high.
    db      $03|(mBit<<5)
  ENDM
; Copy the V flag into the C flag
V2C         MACRO
    BVS     ?vset#          ; Jump if V=1
    CLC                     ; V=0 therefore set C=0
    BRA     ?vend#          ; Jump to end of macro
?vset#
    SEC                     ; V=1 therefore set C=1
?vend#
  ENDM
; Write FastIO
; If mValue is provided, writes the literal value to mBit in the FastIO port.
; if mValue is not provided, the current value of the C flag is used instead.
WFIO        MACRO   mBit, mValue
    EXIT    WFIO first parameter invalid
    ENDIF
    IFMA    2               ; If mValue is present, use that
    IF mValue>1             ; Check that mValue is valid (0 or 1)
    EXIT    WFIO second parameter invalid
    ENDIF
    ; Writes bit 4 of the opcode to the relevant FIO output port
    db      $0B|(mBit<<5)|(mValue<<4)
    ELSE                    ; mValue is not present, so use C instead
    BCS     ?cset#          ; Jump if C=1
    ; Writes a zero to the relevant FIO output port
    db      $0B|(mBit<<5)
    BRA     ?cend#
?cset#
    ; Writes a one to the relevant FIO output port
    db      $1B|(mBit<<5)
?cend#
    ENDIF
  ENDM
; @end
 Post subject: Re: FastIO Macros
PostPosted: Tue Feb 06, 2018 12:58 pm
The V2C macro can be made simpler and faster
V2C         MACRO
    SEC                     ; Assume V=1 therefore set C=1
    CLC                     ; Otherwise V=0 therefore set C=0
?vend#
  ENDM
Andrew Jacobs
PostPosted: Tue Feb 06, 2018 1:11 pm
You're right! Though I think you've got your labels a little mixed up there...
Users browsing this forum: No registered users and 36 guests
