I am porting the Rankin and Wozniak 32 bit floating point code from Doctor Dobbs (posted here:
http://www.6502.org/source/floats/wozfp1.txt) to the Ophis assembler. Reading the code is a head trip because the code flow is a bit convoluted to save space. There are two weird things that I would normally think were bugs if a mere mortal wrote it But given the origin and age of the code, they might actually do something useful.
I was curious if anyone had experience with them.
• The exp function contains an ADC at address 1E29 that doesn’t seem to do anything useful because there’s an LDA M1 directly afterwards.
1E26 18 CLC CLEAR CARRY FOR ADD
1E27 A5 0A LDA M1+1
1E29 69 78 ADC =120 ADD 120 TO INT
1E2B A5 09 LDA M1
1E2D 69 00 ADC =0
1E2F 10 0B BPL CONTIN IF RESULT POSITIVE CONTINUE
Is there some side effect that is being exploited?
• The swap function contains a STY at 1F1E without an LDY prior.
1F1C A2 04 SWAP LDX =$04 INDEX FOR 4-BYTE SWAP.
1F1E 94 0B SWAP1 STY E-1,X
1F20 B5 07 LDA X1-1,X SWAP A BYTE OF EXP/MANT1 WITH
1F22 B4 03 LDY X2-1,X EXP/MANT2 AND LEAVEA COPY OF
1F24 94 07 STY X1-1,X MANT1 IN E(3BYTES). E+3 USED.
1F26 95 03 STA X2-1,X
1F28 CA DEX ADVANCE INDEX TO NEXT BYTE
1F29 D0 F3 BNE SWAP1 LOOP UNTIL DONE.
1F2B 60 RTS
I suspect that the first pass through the loop moves a junk byte, but all the rest of the iterations do something useful, so the junk byte is overwritten on the final iteration.
