displaying a decimal number... using 2 byte value...
LASERACTIVEGUY
Post by LASERACTIVEGUY »
If you have a multi-byte value... for instance... say b1= (2) b2= (2) that equals 514 in decimal... how would you code... loading those two bytes to print the decimal representation...?
LASERACTIVEGUY
Re: displaying a decimal number... using 2 byte value...
This is reference material... question afterwards....
Here is an equivalent routine for converting 16-bit numbers: ; Convert an 16 bit binary value to BCD
; This function converts a 16 bit binary value into a 24 bit BCD. It
; works by transferring one bit a time from the source and adding it
; into a BCD value that is being doubled on each iteration. As all the
; arithmetic is being done in BCD the result is a binary to decimal
; conversion. All conversions take 915 clock cycles.
; See BINBCD8 for more details of its operation.
; Andrew Jacobs, 28-Feb-2004
.ORG $0200
BINBCD16: SED ; Switch to decimal mode
LDA #0 ; Ensure the result is clear
STA BCD+0
STA BCD+1
STA BCD+2
LDX #16 ; The number of source bits
CNVBIT: ASL BIN+0 ; Shift out one bit
ROL BIN+1
LDA BCD+0 ; And add into result
ADC BCD+0
STA BCD+0
LDA BCD+1 ; propagating any carry
ADC BCD+1
STA BCD+1
LDA BCD+2 ; ... thru whole result
ADC BCD+2
STA BCD+2
DEX ; And repeat for next bit
BNE CNVBIT
CLD ; Back to binary
BRK ; All Done.
; A test value to be converted
.ORG $0300
BIN .DW 12345
BCD .DS 3
LASERACTIVEGUY
I need HELP... i am a serious idiot... The 6502 LINK above this one has two routines... I coded it exactly as above (2nd routine)... placing in one set of numbers at 25000 and the other at 20000 (25001, 25002 ect, 20000, 20001)... if I input in the two original positions 1 and 1 (signifying a number of 256... my outputs are 100, 8, 98 --- That makes no sense to me... i post code afterward... If those numbers are correct... the result of 1*256+1= 100,898.... am I missing something?
LASERACTIVEGUY
----------------------------DEC ASSEMBLY
30000- F8 SED
30001- A9 00 LDA #0
30003- 8D 20 4E STA 20000
30006- 8D 21 4E STA 20001
30009- 8D 22 4E STA 20002
30012- 0E A8 61 ASL 25000
30015- 2E A9 61 ROL 25001
30018- AD 20 4E LDA 20000
30021- 6D 20 4E ADC 20000
30024- 8D 20 4E STA 20000
30027- AD 21 4E LDA 20001
30030- 6D 21 4E ADC 20001
30033- 8D 21 4E STA 20001
30036- AD 22 4E LDA 20002
30039- 6D 22 4E ADC 20002
30042- 8D 22 4E STA 20002
30045- CA DEX
30046- D0 DC BNE 30012
30048- D8 CLD
30049- 60 RTS
-------------------------------HEX ASSEMBLY
7530- F8 SED
7531- A9 00 LDA #$00
7533- 8D 20 4E STA $4E20
7536- 8D 21 4E STA $4E21
7539- 8D 22 4E STA $4E22
753C- 0E A8 61 ASL $61A8
753F- 2E A9 61 ROL $61A9
7542- AD 20 4E LDA $4E20
7545- 6D 20 4E ADC $4E20
7548- 8D 20 4E STA $4E20
754B- AD 21 4E LDA $4E21
754E- 6D 21 4E ADC $4E21
7551- 8D 21 4E STA $4E21
7554- AD 22 4E LDA $4E22
7557- 6D 22 4E ADC $4E22
755A- 8D 22 4E STA $4E22
755D- CA DEX
755E- D0 DC BNE $753C
7560- D8 CLD
7561- 60 RTS
10 PRINT CHR$(4);"BLOAD TEST"
11 POKE 25000,0:POKE 25001,1
12 CALL 30000:PRINT PEEK(20000),PEEK(20001),PEEK(20002)
13 REM... LOADING ROUTINE ABOVE...
14 REM PUTTING 0 AND 1 INTO LOCATIONS...
15 REM LOADING, CALLING ROUTINE... PRINTING RESULTS
I'm confused. What is it you want to know?
Also, please surround your code with the CODE tags to improve readability. For example:
30000- F8 SED
30001- A9 00 LDA #0
30045- CA DEX
30048- D8 CLD
30049- 60 RTS
LASERACTIVEGUY
If I have 16 bit number... say (2) (2) that means its 2*256+2 or 512+2 or 514 final result. How do I output that 514 to the screen... (its apple ii, I know the output routines....) how do I get the two bytes to equal 5 1 4 so I can output them... or similar?!?
LASERACTIVEGUY
I forgot... cant use tables... its actually going into a Compiler... now I really sound off my rocker.. cant program ASM but making a compiler..... don't worry bout me... I had to make an assembler before I could program ASM at all... long story!
Separate out the low nybble with AND #$0F (keeping a copy of the original for the high nybble), and separate out the nigh nybble with LSR LSR LSR LSR. After separating out a nybble for a decimal digit, just add $30 to get the ASCII representation; so 1 is $31, 2 is $32, etc.. (For hex digits, there's a gap between 9 at $39 and A at $41 rather than $3A.)
There's no reason a compiler can't use a table; but you don't need a table here anyway.
Klaus2m5
Post by Klaus2m5 »
From VTL02SG:
; Print an unsigned decimal number (0..65535) in var[x]
; entry:   var[x] = number to print
; uses:    outch:, gthan
; exit:    var[x] = 0
prnum:
    lda  #0         ; null delimiter for print
    pha
prnum2:             ;   divide var[x] by 10
    lda  #0
    sta  gthan+1    ; clr BCD
    lda  #16
    sta  gthan      ; {>} = loop counter
prdiv1:
    asl  0,x        ; var[x] is gradually replaced
    rol  1,x        ;   with the quotient
    rol  gthan+1    ; BCD result is gradually replaced
    lda  gthan+1    ;   with the remainder
    sec
    sbc  #10        ; partial BCD >= 10 ?
    bcc  prdiv2
    sta  gthan+1    ;   yes: update the partial result
    inc  0,x        ;   set low bit in partial quotient
prdiv2:
    dec  gthan
    bne  prdiv1      ; loop 16 times
    lda  gthan+1
    ora  #'0'       ;   convert BCD result to ASCII
    pha             ;   stack digits in ascending
    lda  0,x        ;     order ('0' for zero)
    ora  1,x
    bne  prnum2     ; } until var[x] is 0
    pla
prnum3:
    jsr  outch      ; print digits in descending
    pla             ;   order until delimiter is
    bne  prnum3     ;   encountered
rts
There's an all-purpose conversion function in the CODE section of this site. You will need to be able to understand assembly language in order to understand the algorithm used in this conversion function.
LASERACTIVEGUY
I had somebody from the Apple II forum help me with a specific routine that uses partial ROM routines to help... still not concise code but it works (*Only for APPLE II 6502)
Place your 3 binary values (24bit number) into Y,X,A from highest to lowest...
30032-   AC 39 75    LDY   30009
30035-   AE 38 75    LDX   30008
30038-   AD 37 75    LDA   30007
30041-   20 4A FF    JSR   65354
30044-   A9 00       LDA   #0
30046-   B8          CLV
30047-   A2 18       LDX   #24
30049-   C9 05       CMP   #5
30051-   90 03       BCC   30056
30053-   E9 85       SBC   #133
30055-   38          SEC
30056-   26 69       ROL   105
30058-   26 70       ROL   112
30060-   26 71       ROL   113
30062-   2A          ROL
30063-   CA          DEX
30064-   D0 EF       BNE   30049
30066-   48          PHA
30067-   A9 FD       LDA   #253
30069-   48          PHA
30070-   A9 E1       LDA   #225
30072-   48          PHA
30073-   70 E1       BVS   30044
30075-   60          RTS
Thank you for your replies.... anybody make anything INCREDIBLY cool lately?
barrym95838
Post by barrym95838 »
John Brooks is a big name in the 8 and 16-bit Apple retro scene, and I'm "humbly proud" to say that he personally complimented my little binary-to-ASCII routine suggestion recently.
https://twitter.com/JBrooksBSI/status/8 ... 8794545153
https://groups.google.com/forum/#!topic ... y27d_TxDHA
Mike B.
P.S. Hey, I found your thread, so I can see that John has already hooked you up.
https://groups.google.com/forum/#!topic ... pYoWYCdXf0
That routine that he offered still has my TenDivMod DNA in there, but he enhanced it with 8 more bits, a V-flag trick, and a nifty chained RTS trick.
P.P.S. Your code above will not work, because you're ROLing the wrong zero-page addresses. A, X and Y are stored in $45, $46 and $47 respectively after the call to $FF4A.
jgharston
Post by jgharston »
I was needing to update some decimal printout code. I was initially using a routine that used a tables of powers of ten, but was needing to be able to print up to 32-bit values and didn't like the 40 bytes needed for the tens table. After some searching I found this thread, and the link to John Brooks' "clever V flag" routine.
It was almost exactly what I needed, except I needed two additions:
* I needed to be able to specify where the supplied number was, ideally in 0,X format
* I needed to be able to pad with leading spaces.
The following is my adaptation:
* Print up to 32-bit unsigned decimal number
* See forum.6502.org/viewtopic.php?f=2&t=4894
* and groups.google.com/g/comp.sys.apple2/c/_y27d_TxDHA
* On entry:
*  X=>base of four-byte zero page locations
*  Y= number of digits to pad to, 0 for no padding
* Can print fewer than 32 bits by setting higher bytes
* to zero and setting Y appropriately
* On exit:
*  The four bytes at 0,X to 3,X are set to zero
*  X=preserved
*  A,Y corrupted
* Needs OSPAD  = to hold pad count
*       OSTEMP = bit counter
*       OSWRCH = routine to display a character
PRINTDEC    sty   OSPAD      ; Number of padding+digits
            ldy   #0         ; Digit counter
PRDECDIGIT  lda   #32        ; 32-bit divide
            sta   OSTEMP
            lda   #0         ; Remainder=0
            clv              ; V=0 means div result = 0
PRDECDIV10  cmp   #10/2      ; Calculate OSNUM/10
            bcc   PRDEC10
            sbc   #10/2+$80  ; Remove digit & set V=1 to show div result > 0
            sec              ; Shift 1 into div result
PRDEC10     rol   0,x        ; Shift /10 result into OSNUM
            rol   1,x
            rol   2,x
            rol   3,x
            rol   a          ; Shift bits of input into acc (input mod 10)
            dec   OSTEMP
            bne   PRDECDIV10 ; Continue 32-bit divide
            ora   #48
            pha              ; Push low digit 0-9 to print
            iny
            bvs   PRDECDIGIT ; If V=1, result of /10 was > 0 & do next digit
            lda   #32
PRDECLP1    cpy   OSPAD
            bcs   PRDECLP2   ; Enough padding pushed
            pha              ; Push leading space characters
            iny
            bne   PRDECLP1
PRDECLP2    pla              ; Pop character left to right
            jsr   OSWRCH     ; Print it
            dey
            bne   PRDECLP2
            rts
* Example code:
*  LDX #OSNUM   ; X=>four bytes in zero page
*  LDY #8       ; Y=pad to 8 digits
*  JSR PRINTDEC
The Code page on this site is your friend. Scroll to the bottom and you'll see a link to code that will convert a 32-bit integer to ASCII in any one of four number bases.
barrym95838
I think he's looking for something much lighter than that, BDD. Otherwise, he wouldn't have been annoyed by 40 bytes of tables. Maybe something along the lines of this? (I realize it still needs to be modified to meet the requested spec, but I don't think I can significantly improve on the subroutine jgharston posted ... well done, sir!)
