It is currently Sun Oct 06, 2024 11:19 am
 Post subject: HELP HELP HELP . . .
PostPosted: Tue May 25, 2004 3:29 pm
Hello. I have a problem programming in assebly at 6502 processor. I have a project to give to my lecturer on Tuesday 28 May and I want your help.
Here is the deal:
I have a 2 dimensional table (8 bit) and I want to calculate the sum of it's diagonal and the sums of up and down triangular place. For example:
12 52 61
43 06 12
87 01 76
I want to calculate the sum of No -> 12+06+76
and the sum of the No -> 52+61+12
and also the No -> 43+87+01
I would be gratefull if anyone can help me to this. THANK YOU!!! :D
 Post subject: Re: HELP HELP HELP . . .
PostPosted: Tue May 25, 2004 8:23 pm
Site Admin
Please post your questions only once in the forum. Your duplicate question was deleted.
If you'd like to post your code and ask a specific question I'm sure there are people here who would like to help you.
Regards,
Mike
PostPosted: Wed May 26, 2004 6:00 am
I'd use indirect addressing, I've done stuff sorta similar to that before. That way you have 2 axes, the Y register and the address in memory.
I'm sure there's other ways to handle it.
PostPosted: Wed May 26, 2004 5:32 pm
The simplest way would be to put the matrix at a fixed memory location (say somewhere on zero page) and access its values as offsets from the base location, for example
 M+0  M+1  M+2
 M+3  M+4  M+5
 M+6  M+7  M+8
If the values are guaranteed never to add up to a value over 255 then a sequence of CLC / LDA first cell / ADC second cell /ADC third cell will give you the sum for the diagonal or upper/lower triangle. If the sum can be bigger than 255 then keep the low big in the accumulator and use either X or Y to hold the high bytes (hint: after each ADC check for a carry and increment X/Y if needed - remember to clear the carry before the next ADC).
Andrew Jacobs
