Trouble compiling Microsoft BASIC....
cbmeeks
Post by cbmeeks »
I thought I would mess around with compiling my own version of MS BASIC going off of this page:
http://www.pagetable.com/?p=46
When I try to compile (Windows 10), I get these errors:
> c:\tmp\cc65\bin\ca65.exe -D microtan msbasic.s -o c:\tmp\microtan.o
memory.s(139): Error: Range error (-9 not in [0..255])
inline.s(118): Error: Unexpected trailing garbage characters
inline.s(133): Error: Unexpected trailing garbage characters
poke.s(118): Error: Unexpected trailing garbage characters
float.s(777): Error: Range error (-4 not in [0..255])
float.s(1451): Error: Range error (-9 not in [0..255])
init.s(85): Error: Unexpected trailing garbage characters
init.s(443): Error: Unexpected trailing garbage characters
Apparently, I'm not the only one according to an Ubuntu user.
I'm more familiar with KickAssembler and never really worked with CC65.
Any suggestions on what I need to do? I haven't altered anything.
Thanks
rwiker
Re: Trouble compiling Microsoft BASIC....
Post by rwiker »
Thanks
Maybe microtan needs to be in uppercase?
Also, the instructions indicate that there is more involved than just running ca65 on the file msbasic.s:
First duplicate one of the cfg files, and add it to make.sh. cbmbasic2 is a good start, as you can quite easily test the resulting images in the VICE emulator – CC65 can even provide symbol information for the VICE debugger. Add a case in defines.s to define one of CBM1, CBM2, APPLE etc., because you need one flavour of platform specific code, and include your own defines_*.s. For Commodore BASIC, you also need to define CONFIG_CBM_ALL.
cbmeeks
Post by cbmeeks »
Those instructions, from what I can tell, are for creating your own version.
They also say to run the make.sh script. Since I'm on Windows, I just translated one of the commands and arbitrarily picked microtan. I also tried cbmbasic1.
I tried it in uppercase but it made no difference.
make.sh:
if [ ! -d tmp ]; then
	mkdir tmp
fi
for i in cbmbasic1 cbmbasic2 kbdbasic osi kb9 applesoft microtan; do
echo $i
ca65 -D $i msbasic.s -o tmp/$i.o &&
ld65 -C $i.cfg tmp/$i.o -o tmp/$i.bin -Ln tmp/$i.lbl
done
** EDIT **
One easy fix is that it doesn't like the C style comments "/*...*/". So changing them to ";" removes those errors.
** EDIT 2 **
ca65 is clearly failing on assembling negative numbers. One of the examples is:
        lda     #-9
I would have no idea what to put there instead. I'm not sure what the original intent was.
My assumption is that I could translate that to binary instead (%1111_0111) but not sure what to do on this one:
        ldx     #TEMP1-FAC+1
It's evaluating to -9 as well.
Just adding 256 should sort out these negative numbers. The original code will have expected them to wrap within a byte-sized value.
Example: -1 is intended to be $ff. 256-1 or -1+256 is 255, which is $ff.
cbmeeks
Post by cbmeeks »
Duh.
That seemed to do the trick.
I changed one to
        ldx     #-MANTISSA_BYTES + 256
and it worked.
