VetteGuy777 wrote:
When the automatic grader inputs the test numbers it not only enters the number but it enters the code for "enter" aka carriage return.
Hm. What you're saying here isn't wrong, but let's take it apart. What's meant is:
- the first call to GetCharW returns the test number
- the following call to GetCharW returns the Enter
or, more simply,
- sometimes when you call GetCharW you get a test number. Other times when you call GetCharW you get something that isn't a test number.
I think what is being described suggests that the
GetCharW sub is collecting a data stream in a FIFO somewhere (IRQ-driven source, perhaps?) and each call to
GetCharW returns with the "oldest" byte in the FIFO. That's exactly how the
GETCHx subs in my POC's firmware behave (where the
x in
GETCHx refers to one of the TIA-232 channels).
GETCHx does no analysis of what it returns—the calling program has to look at the byte and decide what to do with it. I suspect
GetCharW works in similar fashion.
It sounds to me as though your program need to buffer the bytes retrieved from
GetCharW until the
<CR> is received and
then process the input. Think of
<CR> in this case as meaning "end of data—it's time to process the input."
Here's an example of how I did it in Supermon 816:
;input: INTERACTIVE INPUT FROM CONSOLE CHANNEL
; Preparatory Ops: Zero IBUFIDX or load IBUFFER with default
; input & set IBUFIDX to the number of chars
; loaded into the buffer.
; Returned Values: .A: used
; .X: characters entered
; .Y: used
; Example: STZ IBUFIDX
; JSR INPUT
; Notes: Input is collected in IBUFFER & is null-terminated.
; IBUFIDX is reset to zero upon exit.
input ldx ibufidx ;current buffer index
stz ibuffer,x ;be sure buffer is terminated
jsr dpyibuf ;print default input if any
per dc_cn
jsr sprint ;enable cursor
ldx ibufidx ;starting buffer index
; main input loop...
.0000010 jsr getcha ;poll for input
bcs .0000060 ;nothing
cmp #a_del ;above ASCII range?
bcs .0000030 ;yes, not allowed
cmp #a_ht ;horizontal tab?
bne .0000020 ;no
lda #a_blank ;replace <HT> w/blank
.0000020 cmp #a_blank ;control char?
bcc .0000040 ;yes
; process QWERTY character...
cpx #s_ibuf ;room in buffer?
bcs .0000030 ;no
sta ibuffer,x ;store char
inx ;bump index
.byte bitabs ;echo char
.0000030 lda #a_bel ;alert user
jsr putcha
bra .0000010 ;get some more
; process carriage return...
.0000040 cmp #a_cr ;carriage return?
bne .0000050 ;no
phx ;protect input count
per dc_co
jsr sprint ;cursor off
plx ;recover input count
stz ibuffer,x ;terminate input
stz ibufidx ;reset buffer index
rts ;done, return to caller
; process backspace...
.0000050 cmp #a_bs ;backspace?
bne .0000010 ;no
txa
beq .0000010 ;no input, ignore <BS>
dex ;1 less char
phx ;preserve count
jsr gendbs ;generate destructive backspace
plx ;restore count
bra .0000010 ;get more input
; input waiting loop...
.0000060 wai ;wait for datum
bra .0000010
