It is currently Sat Sep 21, 2024 8:03 pm
PostPosted: Wed Feb 17, 2016 9:15 pm
I'm trying to disassemble some code and cannot reconcile it with my interpretation of the datasheet.
During the initialization we have
lda #$00
sta viabifr
sta viaaifr
lda #$80
sta viabier
sta viaaier
I'm guessing this is attempting to disable interrupts but seems wrong.
I don't see what writing all zeros will achieve, the Rockwell datasheet reads
... individual flag bits can be cleared by writing a "1" into the appropriate bit of the IFR.
The write to the IER looks equally odd, the datasheet says
Selected bits in the IER can be set by writing to the IER with bit 7 in the data word set to a 1.
For each zero, (of bits 6 to 0) the corresponding bit will be unaffected.
So this looks like a no-op.
Am I misunderstanding the datasheet or is the code nuts?
PostPosted: Wed Feb 17, 2016 10:02 pm
I agree.
Of course the IFR and IER are cleared anyway by a reset. So maybe the code snippet was included "to be on the safe side," and the author never realized it accomplished nothing.
PostPosted: Thu Feb 18, 2016 10:10 am
Yep. You clear the enables by reading them and writing back the value
    64 00:0004: AD CE 7F                     lda     VIA1_IER                ; Ensure no via interrupts
    65 00:0007: 8D CE 7F                     sta     VIA1_IER
    66 00:000A: AD EE 7F                     lda     VIA2_IER
    67 00:000D: 8D EE 7F                     sta     VIA2_IER
Writing to the flag register doesn't always work. Some of the interrupt flags can only be cleared by updating other registers.
PostPosted: Wed Sep 09, 2020 10:13 am
My interpretation of the datasheet is that if you want to disable all interrupts on the VIA, then you actually would write:
LDA %01111111  ;; a bit 7 `0` means any bit 0-6 `1`s are a "clear"
STA VIA1_IER
STA VIA2_IER
This can't be right. Reading the IER wouldn't achieve this because the datasheet says it will _always_ return a 1 for bit 7 and writing 0s _always_ ignores that particular bit. So, for example, if you had all interrupts enabled:
LDA VIA1_IER  ;; A is now %11111111
STA VIA1_IER  ;; a bit 7 `1` means any subsequent bit 0-6 `1`s are a "set", not a "clear"
Users browsing this forum: 8BIT and 10 guests
