malcontent wrote:
I did see your math package, but am I wrong when I see that just one of the required tables is 256k? No way this would help with legacy computers. Unless staight BCD is still faster even without tables. While this is ostensibly about making my simulator for c64, it's more about improving methods on all CBM machines without having to fill the RAM with code and tables leaving no room for anything else.
The biggest table (inverses) is 256KB, since it has 64K 32-bit answers. Most tables are 128KB, two bytes for each 16-bit answer. Near the bottom of the index page there are suggestions for implementation, including a synchronous-serial interface for 8-bit computers that don't have nearly enough memory or even the address space for it. Even communicating over synchronous serial, it's still much faster than having to actually calculate the values. In the case of a C64, such memory would probably be on a board that gets plugged into the back, unless you want to wire it internally. For only the price of postage, I do supply one-megabyte EPROM pairs, pre-programmed with the whole set of tables by our late forum member
NightmareTony who died with cancer in Nov 2012 just a month or two after the last time I saw him. (My EPROM programmer doesn't do EPROMs that big, so he helped me out, even donating the EPROMs.)
Tables or no tables though, part of my point is the unexpected value and capability of scaled-integer math which is more efficient if the machine does not have a floating-point coprocessor.
