It is currently Sat Sep 21, 2024 11:26 am
PostPosted: Sun May 01, 2016 8:45 am
I'm not certain if I found an anomaly or if I'm doing something wrong. In some recent testing, I've noticed that the BRK bit is being set in the processor status register on a PLP, but the byte it pulls is a $00. Code is simple enough, I invoke code via a CNTRL key (to limit any other code interfering) to run a small routine. Note: CPU is W65C02S.
;Break test - invoked by CNTRL-Y
BRKTEST   ;Test theory on BRK flag being set on PHY/PLP with zero pushed on the stack
               LDY   $04FE   ;Load Y reg with value from RAM
               PHY   ;Push it to the stack
               PLP   ;Pull it to the Processor status reg
               PHP   ;Push it back to the stack
               PLX   ;Pull it to X reg
               STX   $04FF   ;Store it in memory for viewing
               RTS   ;Return to caller
Regardless of how I load $04FE, the result in $04FF always shows the BRK bit being set. I searched around and haven't found this documented anywhere. Also, I have a routine in my BIOS which handles a software break (send a null character to the board). This is handled correctly and the BRK bit is not set. Executing code which does execute a BRK instruction does set the BRK flag. The unused status bit (emulation bit for the 65C816) always shows as set when testing the processor status which is normal. I also have a full ISR that handles both HW interrupts and the BRK instruction and this works correctly. Has anyone else noticed this odd behavior?
PostPosted: Sun May 01, 2016 9:27 am
This is a common question! Nothing is wrong. The confusion arises because there is no B bit in the status register, and that's not obvious and often not described correctly. See 6502 'B' flag & BRK opcode by Brad Taylor and for more details and references this page on the visual6502 wiki.
PostPosted: Sun May 01, 2016 3:40 pm
See also the BRK section of the 6502 interrupts primer.
PostPosted: Mon May 02, 2016 9:39 pm
Thanks Ed, I hadn't seen that before... I did do some digging in my old (hardcopy) manuals but nothing around that was covered.
Garth, thanks... I should visit your site more often ;-)
I have concluded that my current C02 BIOS/Monitor is working as designed! At some point I should post the updated source code, but then again... I think most are beyond needing yet another BIOS and Monitor.
Users browsing this forum: Google [Bot] and 15 guests
