It is currently Sun May 12, 2024 9:56 pm
PostPosted: Wed Nov 11, 2015 11:25 am
I have some simple 6502 type assembler directives using the tass64 assembler as follows:-
.if   DeBugSubRoutne   | DB_Main =   True
Prog_DataBRK   =   MemoryTop+$800      ; Increments need to be whole "$200"
.else
Prog_DataBRK   =   MemoryTop      ; Upper Program Memory Stop!!
.fi
UpperMemLimit   =   Prog_DataBRK-1
When Assembling th code the assembler creates a list file as follows:-
=$1000               LowerMemLimit   =   $1000
=$4300               MemoryTop   =   $4300
=19200               Prog_DataBRK   =   MemoryTop+$800      ; Increments need to be whole "$200"
=19199               UpperMemLimit   =   Prog_DataBRK-1
My simple questin is how do I force the assembler to print the "Prog_DataBRK" in HEX format,.. I have tried some variations around using $ sign and looked through the docs,.. all to no avail,.. does anyone know if this is possible, and that I have missed the obvious..
Many Tx
