It is currently Thu Sep 19, 2024 10:13 pm
PostPosted: Wed Oct 07, 2015 8:41 am
There's a very interesting thread over at HP Museum, where Thomas Klemm has noted that Python is a convenient high-level language which compiles to bytecode and which includes introspection - so you can automatically convert from python, via bytecode, to a machine language of choice. Python can disassemble its own bytecode so the transformations can be text-based.
The whole thing works well if the machine language of choice has a structural resemblance to python bytecode - in this case it's Focal, which runs on the HP-41C calculator. Perhaps one could convert to a virtual machine like Forth or Sweet 16, or perhaps to assembly language, perhaps in a threaded style.
Thomas put up an example you can run in your browser. His 300 line program converts
def gcd(a, b):
    while b != 0:
        a, b = b, a % b
    return a
to
LBL "GCD"
STO 01 ; b
RDN
STO 00 ; a
RDN
LBL 00
RCL 01 ; b
0
X=Y?
GTO 01
RCL 01 ; b
RCL 00 ; a
RCL 01 ; b
MOD
X<>Y
STO 00 ; a
RDN
STO 01 ; b
RDN
GTO 00
LBL 01
LBL 02
RCL 00 ; a
RTN
PostPosted: Wed Oct 07, 2015 11:21 am
Very interesting.
Michael A.
PostPosted: Thu Nov 12, 2015 5:28 pm
I contribute to a java bytecode compiler project (java_grinder), which is based on a similar concept. Some random thoughts:
-It's totally worth doing this with Python, especially if you can work out a way to call ML routines. Then its just like mixing BASIC/ML back in the day - but with a much nicer & faster language.
-You can also interpret the bytecode as you see fit. For example, my efforts were limited to 16-bit integers and lack floating-point support.
-Using a separate data stack made life a lot easier, see:
http://wilsonminesco.com/stacks/virtualstacks.html
Working on this sort of stuff has been very rewarding for me, I highly encourage it.
PostPosted: Fri Jan 15, 2016 1:56 pm
I've actually used Python to compile my Forth-83 implementation for the VIC-20. The input source code is entirely Forth (based on the 6502 reference model) and the compiler generates a binary image which contains the elemental words (compiled from Forth ASSEMBLER words) and the rest as a list of constituent words.
Using Python meant building and testing the compiler was easy, I have classes for stacks, target code blocks etc and I can dump the contents of the dictionary to help with debugging.
PostPosted: Fri Jan 15, 2016 3:28 pm
Welcome, srowe. Nice work defying the "chicken or the egg" problem! As you know, it's usually necessary to use a conventional assembler to create the Forth kernal, which means low-level definitions in the reference code (written in the RPN syntax expected by Forth's own assembler) can't be used.
You may wish to elaborate on what you've done by starting a thread in the Forth section of the forum.
PostPosted: Fri Jan 15, 2016 4:37 pm
Yes, welcome! I see there is a thread elsewhere (V-FORTH - Forth-83 for the VIC) with an attachment too.
PostPosted: Sun Jan 17, 2016 9:50 am
Thanks. That version is a little out of date (but the git URL is still valid). I'll create a post in the Forth section shortly.
