It is currently Sun Sep 22, 2024 10:20 am
PostPosted: Tue Sep 08, 2015 12:37 am
I have a pretty good handle on the direction and data registers of the 6522. But the timers are confusing me. I read the data sheet and it talks a lot about interrupts with the timer, but code samples I've seen simply set a value in the timer and busy wait until the timer pops. In the ISR they don't do anything to service the interrupt or clear the interrupt. But when I try that I'm getting an interrupt and since my ISR doesn't clear it, I get stuck.
There's a discussion in the data sheet about control registers which might disable interrupts, but I did not quite get what they were talking about. Some code samples would be helpful, but the data sheet is lacking them.
Any pointers to code samples? Thanks in advance.
PostPosted: Tue Sep 08, 2015 12:49 am
There are subtle ways an ISR or other code can clear a 6522 interrupt flag, so perhaps it's there but you don't recognize it. Simply reading some of these registers will clear the associated interrupt flag! This came up recently in connection to another topic. The attached table gives a rough idea -- HTH
PostPosted: Tue Sep 08, 2015 1:21 am
Take a look at the ISR and timer support in my C02 mini BIOS. It uses timer 1 for RTC and timer 2 for an accurate delay. Code is well commented and should be easy to understand. Link is here:
viewtopic.php?f=12&t=3045
PostPosted: Tue Sep 08, 2015 1:44 am
Thanks, I'll take a look later.
PostPosted: Tue Sep 08, 2015 6:18 am
And make sure you go through the interrupts primer at http://wilsonminesco.com/6502interrupts/ . It also has code associated with the timers, although not all modes.
